Bay Area Trooper People?! New guy here saying 'Hi' #929950 02/07/09 05:24 PM
California_Dreamin Offline OP
Hello everyone! New guy here, wondering if there are any other bay area folks around here? I have an '89 trooper with 2.8 V6 and 5 speed, 150k miles.
Also looking for a mechanic who knows Troopers, to help diagnose my driveline problem.
Cheers,
Bill
'89 Trooper 2.8 5spd
Re: Bay Area Trooper People?! New guy here saying 'Hi' [Re: California_Dreamin] #929951 02/09/09 05:15 PM
Cronk Offline
Welcome Bill,
I'm on the central coast right now, will be on the North Coast in a few months. Good to see another 1st gen Trooper in the mix. There are others out here, give them time and I'm sure they'll chime in.
Describe the problem with your driveline. It may be something you can do yourself and save some money.
Joe
02 Rodeo, 89 Trooper and a few P'ups
Re: Bay Area Trooper People?! New guy here saying 'Hi' [Re: California_Dreamin] #929952 02/09/09 07:14 PM
dvtrooper Offline
Welcome to the wire, where abouts in n.cal are you at? i am in the northern part about 50miles n.of sf. Don
sua dana 44 conversion 5.38 gears, 4.3tbi,700r,dana 300 w/tera low 4:1 gears
Re: Bay Area Trooper People?! New guy here saying 'Hi' [Re: California_Dreamin] #929953 02/12/09 06:26 AM
Scott F. Offline
Don't gots a trooper, just two rodeos.
Live in the valley now but from SanJose.
So whats the issue with the truck?
Scott F.
1995.5 Rodeo V6 Auto
Not enough money to put much here! I am taking donations <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Bay Area Trooper People?! New guy here saying 'Hi' [Re: Scott F.] #929954 02/13/09 08:23 PM
Hi, and thanks for the replies. My Trooper lives in Richmond, CA, at my work. I spend most my time there too, might as well live there.
The problem with my driveline is odd. Shows up as diff whine, a broken U joint in rear. The truck appears to have never been hit, and everything looks straight and stock from underneath. So I don't think it's an alignment issue from collision damage
I think I need to replace all mounts to get to a baseline. Truck has 150k miles (I've owned it for 3 years and 2k miles).
I've replaced transmission mount (it's a 5 speed), and have engine mounts I need to install. Diff mount seemed OK, but I don't really know what I'm looking at. We checked and adjusted that big nut on front of diff. The U joint that blew had passed a visual/pull test. Accell/decell changes the noise, which gets much louder on decell. By feathering the throttle just right, you achieve a stoichiometric (sp) stasis that eliminates the noise altogether - but that's fleeting.
What other mounts might I check: diff, transfer case, center bearing(s), stuff like that?
Anyway, love my Trooper, just got some new tires on her, and after a full service she'll be ready for another 150k miles. Been reading up on the small block V8 swaps, I'm crazy enough that it appeals to me. but probably just do the standard 3.4 and not get too crazy about it.
Re: Bay Area Trooper People?! New guy here saying 'Hi' [Re: California_Dreamin] #929955 02/13/09 09:29 PM
mlclark Offline
Isuzu Moderator
You "checked and adjusted that big nut on front of diff"?
That nut is not "adjustable". If it was loose, you had a problem. If you tightened it, you have a problem. It sounds like you may have a pinion and or pinion bearing problem. Noises that change with vehicle or engine speed are usually not a mount or bushing issue.
Change the rear diff fluid. Is is sparkly? If so, that is your pinion bearing coming out one sliver at a time.
Good luck,
Michael
Re: Bay Area Trooper People?! New guy here saying 'Hi' [Re: mlclark] #929956 02/14/09 05:26 AM
Cronk Offline
Sounds like the slip yoke on the tranny to me. From the sound of it, mine did the same thing. My solution was to pull the driveshaft, packed the slip yoke with grease and put it all back together.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6140 MB (Peak: 0.6927 MB) Data Comp: Off Server Time: 2026-10-24 23:52:01 UTC
