89 trooper spare tire carrier removal? #930392 02/09/09 07:32 PM
rhouser Offline OP
how do u take the spare tire carrier off 89 trooper?
Re: 89 trooper spare tire carrier removeal? [Re: rhouser] #930393 02/09/09 07:36 PM
Craig Offline
There are nuts behind the trim panel.
Buy a Trooper. You'll be glad you did.
Re: 89 trooper spare tire carrier removeal? [Re: Craig] #930394 02/10/09 02:21 PM
rhouser Offline OP
nope i looked last night
Re: 89 trooper spare tire carrier removeal? [Re: rhouser] #930395 02/10/09 05:14 PM
mlclark Offline
Isuzu Moderator
Aren't there 4 torx or allen headed bolts that hold the bracket to the door? I thought the nuts were captured within the structure of the door?
Good Luck,
Michael
Re: 89 trooper spare tire carrier removeal? [Re: mlclark] #930396 02/10/09 08:09 PM
rhouser Offline OP
i couldnt find any??
Re: 89 trooper spare tire carrier removeal? [Re: rhouser] #930397 02/11/09 02:03 AM
mlclark Offline
Isuzu Moderator
Oh, they are there. They have a security head on them. It would be pretty silly to make the whole thing removable with 4 hex headed bolts.
Time to get out the welder and put some nuts on there or get fancy with the vice grips.
Michael
Re: 89 trooper spare tire carrier removeal? [Re: mlclark] #930398 02/11/09 05:14 AM
maxwell417 Offline
Vise grips, righty tighty, lefty loosey <img src="/forums/images/graemlins/smile.gif" alt="" />
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: 89 trooper spare tire carrier removeal? [Re: maxwell417] #930399 02/11/09 04:19 PM
rhouser Offline OP
so how do i get the security heads off?
Re: 89 trooper spare tire carrier removeal? [Re: rhouser] #930400 02/11/09 05:38 PM
mlclark Offline
Isuzu Moderator
You either find the right socket. Where to start, I don't know. Isuzu?
Other than that, get out the vice grips and go to town. Or, you could weld nuts to each one and remove with a regular socket.
Good Luck,
Michael
Re: 89 trooper spare tire carrier removeal? [Re: mlclark] #930401 02/11/09 11:15 PM
JLEMOND Offline
Michael
FIND A TOOL STORE , NORTHERN TOOL HAS THESE , THAT ARE MADE BY IRWIN TOOLS , THEY COME IN A KIT AND ARE THE BEST INVESTMENT YOU WILL EVER MAKE , FOR GETTING BOLTS OR NUTS OUT, THEY ARE REVERSE CUT TEETH INSIDE , COMMONLY CALLED BOLT OUTS, GET THE METRIC SET AND THEN USE THE ONE FOR A 15 MM BOLT HEAD WITH A 3/8 TH RATCHET AND THEY WILL COME RIGHT OUT , ABOUT 20 BUCKS JERRY
PHP: 7.4.33 Page Time: 0.028s Queries: 16 (0.022s) Memory: 0.6361 MB (Peak: 0.7425 MB) Data Comp: Off Server Time: 2026-11-03 03:02:12 UTC
