**UD** 3.0 FI stalling, difficulty starting - Backfiring! #930551 02/10/09 08:45 PM
stony-man Offline OP
This morning, my '92 didn't want to start. I've NEVER had any problems with it starting..it has always fired immediately. I tried turning it over for a few seconds, and it didn't fire at all. I then checked my fuses and relays (since I'd had that issue with the heater blower), and they were all good. I then tried starting it with the accelerator on the floor, and it sputtered, and started. I drove it about 10 miles to work. Had to give it some gas to start it shortly thereafter (I drive around between different locations during the day). It has also stalled a couple times in intersections, while I was waiting to turn. It seems to idle fine, runs fine other than when it is stalling. If I let it idle, it has a slight hesitation if I rev the engine, and only if I let the RPMs settle all the way down to idle.
My first thought was fuel filter(s)? I don't even know where it is (aren't there two?), so I'll be lookingin the manual when I get home tonite. I was just hoping someone with similiar problems could provide more insight into the problem, or reinforce that I'm on the right track?
Thank you all.
Okay, I came home from work, changed clothes, hopped back in to go to my parents house. It took a while to get started, and then it fired up and seemed to run okay. I pulled out into traffic, and it stalled. I tried to start it while rolling, and it started, sputtered, and backfired. Did that again, and then ran fine for the few miles to parents house. Thought perhaps that behaviour would aid in the diagnosis.
- '92 LWB V6 3.0 5 sp
33x10.5 BFG M/Ts & Bouncy seat
- '95 LWB V6 3.0 Auto (Scrapped)
- '05 Montero Limited. Bone stock <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: 3.0 FI stalling, difficulty starting [Re: stony-man] #930552 02/10/09 08:51 PM
StockRaider Offline
Your fuel filter if its similar to a Gen1 is right under the drivers seat along the frame. Should have a skid plate around it. Sounds almost like a dose of bad gas to me.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: 3.0 FI stalling, difficulty starting [Re: StockRaider] #930553 02/10/09 08:58 PM
It drove fine all day yesterday. It did rain all night, and it's MUCH warmer today (so had some condensation under the hood?)...maybe something is damp? I looked at my plug wires and distro, and everything LOOKED good.
Re: 3.0 FI stalling, difficulty starting [Re: stony-man] #930554 02/11/09 09:12 PM
No suggestions? <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: 3.0 FI stalling, difficulty starting [Re: stony-man] #930555 02/11/09 09:32 PM
V
vr4 Offline
pull the ecu and check it for leaking caps.
cant think of anything else obvious. sorry.
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Re: 3.0 FI stalling, difficulty starting [Re: vr4] #930556 02/11/09 10:02 PM
Talking out my theoretical <img src="/forums/images/graemlins/butwiggle.gif" alt="" />...
If he has changed nothing about the running, then something has changed on him, right? Under that assumption, wouldn't backfiring mean fuel that was perviously delivered and burned, is now delivered and not getting burned?
Shouldn't he pull the plugs and check condition there? What about the dizzy? When was the last tune up?
Could a bad coil (single, not the 3x2-packs) cause this?
Re: 3.0 FI stalling, difficulty starting [Re: MontyMcV] #930557 02/11/09 10:39 PM
crankwalk Offline
Sounded exactly like what my truck was doing when it was a bad coil. Hit or miss, when it was good it was fine for 2 days and when it was bad it was a chore to drive. 40 bucks at autozone and that took care of it.
'73 Datsun 240Z
'87 Toyota Land Cruiser FJ60,4 sp,2 in OME lift, 35" BFG MT
'15 Toyota Prius C
Re: 3.0 FI stalling, difficulty starting [Re: crankwalk] #930558 02/12/09 03:16 AM
Easy to check, just need to put a meter to it. FSM gives the specs.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6277 MB (Peak: 0.7234 MB) Data Comp: Off Server Time: 2026-05-26 04:51:31 UTC
