fuel problems!
#930627
02/11/09 03:11 AM
so i have an 88 yota pickup with efi 4 cylinder. at first i was only having problems when i was accelerating, then it started to act sort of like it was starving for fuel as i was at a steady speed on my way to work in the mornings only, now it has gotten to were it will barely start in the morning after fighting with it for a good 5 mins or so. gave it a lil shot of ether to help. i have checked my tps and afm and they checked out. what else should i check or has anyone else had this problem and knows what it is? please help.
"IM THERE BUDDY"
Re: fuel problems!
[Re: wytee]
#930628
02/11/09 03:24 AM
When's the last time the fuel filter was changed? Start there.
Also give your oil dipstick a whiff. If it smells like fuel, you've got a leak somewhere that's depressurizing the rail.
Re: fuel problems!
[Re: kewlynx]
#930629
02/11/09 03:58 AM
changed the fuel filter about 10000 miles ago and ill go check the dipstick realquick.
"IM THERE BUDDY"
Re: fuel problems!
[Re: wytee]
#930630
02/11/09 04:09 AM
i couldn't start my truck 2 yrs ago & turned out the solder connection btwn wire & fuel pump on top of the gas tank was corroded...Resoldered, problem fixed.
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/ Camper/33x10.5BFG-AT/Open 4:88/1.5"BJS/ +2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
Re: fuel problems!
[Re: allochris]
#930631
02/11/09 04:12 AM
ill check the wire first thing in the morning and no fuel in oil.
"IM THERE BUDDY"
Re: fuel problems!
[Re: wytee]
#930633
02/11/09 11:24 PM
Re: fuel problems!
[Re: 4Crawler]
#930634
02/19/09 02:52 AM
ok so i have now changed my cold start injector and my tps and tried the jumper. the jumper blew a fuse in my main fuse box on the other side of the engine compartment. my truck will start right up in the morning then die. it will do that a good 4 to 5 times the idle time being longer each time then it will be long enough for me to start heading down the road, make it about 3 miles and die again. after i pop the clutch and get her going again she doesnt die the rest of my 40 mile trip to work. also now when i push my clutch in my truck idles high like i forgot to release the gas pedal for a few seconds then level out.
"IM THERE BUDDY"
Re: fuel problems!
[Re: wytee]
#930635
02/22/09 12:37 AM
check out your TPS connection and test the TPS its self -- I had the same problems this summer on my 86 1 ton 22re and it was the TPS - it would take about6-8 tries to start and it would fire and run for just a few quick seconds -- also try unhooking the battery and clearing the computer -- and try restarting it, it should fire right up, but only for the 1st time then the code gets set again -- good luck ! web page
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6267 MB (Peak: 0.7293 MB) Data Comp: Off Server Time: 2026-06-07 06:08:45 UTCValid HTML 5 and Valid CSS
