ifs rebuild, a-arm, sway, tie-rods #930682 02/11/09 07:02 AM
rolled Offline OP
ok kids,
sway bar hardwear was rusted together, had to be broken and cut off (spacer rust-fused to bolt).
now the hole on the a-arm that the sway hardwear goes thru looks a little oblong. is this a problem? also the spicer hardwear i got doesn't have the retainer for the bushing that sits on top of the a-arm. will the a-arm and its mis-shapen hole eat my new bushings?
i was told from the previous owner that a mechanic wanted to replace the lower a-arm because there was a bolt that was frozen. could this be the adjusting cams? i just can't imagine replacing the arm because of a rusty bolt.
i'm doing the tie rods too. just tell me that spending $160 for all four ends is ok. i could do 'em for $60 on the cheap, but i don't want to do them all the time. just say its ok.
i'm really resisting the urge to put new shocks under it while i've got everything apart.
please see this post for a joint tulip/ tripod joint question: http://www.4x4wire.com/forums/showf...mp;amp;o=14&fpart=2&vc=1
cheers,
j.
rolled it on a snowbank. now i'm not afraid to scratch it. liberation.
Re: ifs rebuild, a-arm, sway, tie-rods [Re: rolled] #930683 02/11/09 03:18 PM
G
Greg_Canada Offline
Remember, you get what you pay for, i always spend $ on the best if i can afford it.
Might as well throw some bilsteins under it, theyre pretty easy to change...
89 4Runner
Re: ifs rebuild, a-arm, sway, tie-rods [Re: Greg_Canada] #930684 02/11/09 05:53 PM
Staceman Offline
I wouldn't worry about the oblong hole for the sway bar. Me, like a lot of folks, don't even use a swaybar. Leave it off, go for a ride. You just may decide to leave it off.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5962 MB (Peak: 0.6503 MB) Data Comp: Off Server Time: 2026-05-29 18:55:04 UTC
