front brake disks #931082 02/14/09 05:27 PM
xrtim Offline OP
I've been looking for new brake disks for my '81 4x4 and so far have not found any online. Does anyone know of a site that has them? Thanks in advance I know something will come up here. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: front brake disks [Re: xrtim] #931083 02/14/09 05:59 PM
sassmatt72 Offline
are you looking for stock, or are you updating to the vented rotors and wider calipers from an ifs truck. was thinking that mine came from trailtech? good luck, if you do the update make shure you shell out for the stainless steel flexable lines, and the short hard lines at the caliper. the flex lines make a huge improvement on the braking power, and the short hard lines are so cheap , and with new ones all you need to do is get the connection at the frame side of the old rubber flex line free (it's not so bad because of it's location)
NOTE TO ALL DOING BRAKE LINE WORK.... clamp a vise grip as hard as you can on the outside of your brake line wrench, this takes up the slack in the fit and greatly reduces the likleyhood of the brake line wrench slipping and killing the end of one of the long hard lines.... good luck to all. matt
sweet 85 4runner
Re: front brake disks [Re: sassmatt72] #931084 02/14/09 07:53 PM
xrtim Offline OP
Thanks for the info. I was not planning on upgrading to vented disks unless I could do it without changing calipers. The calipers on these old trucks are pretty impressive considering the year they're made. I got 180k out of the old disks, I think OEM replacements should make it okay. I will upgrade to stainless lines though when I do this. I already have them in the garage ready to go. Just need to find the disks????
Re: front brake disks [Re: xrtim] #931085 02/14/09 08:12 PM
Stevie Offline
Here's what I found....and there are Kragens all over town!
http://shop.oreillyauto.com/Product...=A&searchfor=Brake+Rotor+-+Front
'80 4X4 Longbed
Re: front brake disks [Re: Stevie] #931086 02/15/09 01:14 AM
xrtim Offline OP
I don't know why I didn't think of checking the easy places first. Awesome. I found what I needed. Thanks... <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: front brake disks [Re: xrtim] #931087 02/15/09 03:50 AM
roadtoad1 Offline
Re: front brake disks [Re: roadtoad1] #931088 02/15/09 05:02 PM
xrtim Offline OP
Wow, this guy has an excellent deal that I'll probably do. I assume the IFS front calipers will bolt right up to the mounts I have since there is no mention of any adapters anywhere? This will work out. thanks..
Re: front brake disks [Re: xrtim] #931089 02/16/09 02:56 AM
roadtoad1 Offline
may require the use of spacers so existing wheels will clear the replacement brake calipers.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6199 MB (Peak: 0.6984 MB) Data Comp: Off Server Time: 2026-05-29 23:50:32 UTC
