Added some gauges to the 95 SR
#931644
02/17/09 11:23 PM
Well, my oil pressure gauge was broken so I wanted to replace it with an accurate aftermarket gauge. At the same time, I have visions of turbos dancing in my head.... so I added an AEM Tru Boost for near future use and a trans temp gauge since I've been doing a lot of towing. I have a Wideband O2 to add, but I haven't purchased a gauge holder for it yet. Here is the results of the install. I still have to install the temp sensor for the trans temp gauge. ![[Linked Image]](http://i12.photobucket.com/albums/a248/Hans91GT/Montero/P1015323.jpg) ![[Linked Image]](http://i12.photobucket.com/albums/a248/Hans91GT/Montero/P1015322.jpg)
96 Montero SR 94 Dodge Stealth TT 92 Mitsu Galant VR4 91 Mitsu 3000GT 95 Mitsu 3000GT, carbon black, for sale 95 Mitsu 3000GT, white, for sale 92 Mitsu 3000GT VR4, silver, for sale
Re: Added some gauges to the 95 SR
[Re: Hans_GZP]
#931645
02/18/09 12:16 AM
Did you use the same sender for the oil pressure gauge? If so, does it read the same?
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
[Re: Bernoulli]
#931646
02/18/09 12:24 AM
It's a different sensor and reads quickly... not like the stock guessing gauge. This one has a digital read out in the middle to tell you your actual oil pressure in numbers. It also has LED's on the outside of the gauge to light up the area that the oil pressure is at... just like a needle.
[Re: Bernoulli]
#931647
02/18/09 12:30 AM
Here is a picture of the gauge on. ![[Linked Image]](http://i12.photobucket.com/albums/a248/Hans91GT/Montero/P1015335.jpg)
[Re: Hans_GZP]
#931648
02/18/09 02:50 AM
That's cool. I like those <img src="/forums/images/graemlins/kewl.gif" alt="" /> So the oil pressure is mechanical? Goes up and down with engine rpm? <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: Mad_Scientist]
#931649
02/18/09 04:13 AM
Electrical. Sender is a pressure transducer.
Nice, but I like a mech oil pressure gauge. It can tell you more info due to response speed.
[Re: fasteddy]
#931650
02/18/09 04:49 PM
The response on the new electrical gauges are instant. Nothing like stock. I prefer electrical because I don't like having an oil line (or coolant) running inside the cab of my vehicle. If that thing springs a leak, you got oil (or coolant) everywhere inside your car/truck.
[Re: Hans_GZP]
#931651
02/19/09 01:25 AM
I found a nifty little valve from grainger that is a catastrophic leak stopper. If flow in the line exceeds the rating, it pushes a ball into a seat against a light spring pressure to seal the line. No flow in a pressure gauge line to speak of unless it pops a leak.
The other reason I like mech pressure gauges is that they are easier to read fast, and the needle movement is an eyecatcher for me that a changing number is not, and I don't think the moving perimeter leds would do it either. Just personal pref.
It's easier and much faster for me to spot a gauge with a needle out of place than it is to read and compare a number.
[Re: fasteddy]
#931652
02/19/09 04:49 PM
I found some fancy computer setup that I can have these gauges output their signal to. It will flash at me if something is out of spec. I can set it up so that it won't flash at idle, where oil pressure is known to be pretty damn low. I've got a lot of gadgets going into this thing in the next month, so just stay tuned. I may change your mind on electrical gauges :p
[Re: Hans_GZP]
#931653
02/20/09 12:16 AM
I found some fancy computer setup that I can have these gauges output their signal to. It will flash at me if something is out of spec. I can set it up so that it won't flash at idle, where oil pressure is known to be pretty damn low. I've got a lot of gadgets going into this thing in the next month, so just stay tuned. I may change your mind on electrical gauges :p Never happen! Fasteddy still has analog clocks and a rotary cell phone. <img src="/forums/images/graemlins/nana.gif" alt="" />
HUMMER .25: No need to compensate.
1989 Dodge Raider: 3.0/5 1992 Chrysler LeBaron Convertible: 3.0/A 1994 GMC Safari: 4.3/A
