brake lines #931686 02/18/09 03:32 AM
G
goeco Offline OP
I am getting ready to do some brake work and wanted to know if the stainless steel lines are worth the money?
Dave
Re: brake lines [Re: goeco] #931687 02/18/09 03:49 AM
CJMT100 Offline
Never tried them myself but I heard that they dont flex as much which equates to a more positive pedal stiffness when you brake. Also stainless doesnt rust as easy.
More important than stainless lines is using good pads and rotors. I run brembos and hawk LTS pads with no complaints.
Re: brake lines [Re: CJMT100] #931688 02/18/09 03:58 AM
G
goeco Offline OP
Thanks.
Have you heard of a good place to purchase them?
Where did you get your pads and rotors?
Re: brake lines [Re: goeco] #931689 02/18/09 04:01 AM
CJMT100 Offline
Ya know, I dunno where to get the lines tbh.
I got my rotors and pads from tirerack as they were the cheapest at the time. You may want to check out auto parts warehouse, see if your local parts store carries them or check the net out a bit more too.
Re: brake lines [Re: goeco] #931690 02/18/09 04:41 AM
N
NorCalT1 Offline
I have them and think they are worth it. Check out ebay; http://cgi.ebay.com/ebaymotors/93-9...torsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
These are what I have, only I believe mine are a bit longer because of my 4" lift. Under $100 shipped for all four.
Re: brake lines [Re: NorCalT1] #931691 02/18/09 05:37 PM
G
goeco Offline OP
I appreciate it. My T is at stock height so I am assuming these will work.
Re: brake lines [Re: goeco] #931692 02/19/09 02:18 AM
Jake97T Offline
get the brake lines from marlin crawler.
Re: brake lines [Re: goeco] #931693 02/19/09 05:48 PM
foxtrapper Offline
I've run them on various vehicles and bikes. Good ones have virtually no stretch, so the pedal feel is firm. However, good oem lines don't stretch either, so the pedal feel is firm.
They can be a worthwhile upgrade if replacing worn or questionable lines. But if your OEM lines are fine, I wouldn't go replacing them.
'97 T-100 SR5
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6208 MB (Peak: 0.6985 MB) Data Comp: Off Server Time: 2026-06-07 11:37:22 UTC
