4x4 engauge-99 3.5 #932069 02/20/09 03:24 PM
three5 Offline OP
When I activate the 4x4 switch the indicator flashes but fails to engauge 4 wheel drive. According to the OM the continud flash means no engaugement.
Any suggestions?
Thanks,
3 5
Re: 4x4 engauge-99 3.5 [Re: three5] #932070 02/20/09 04:44 PM
BigSwede Offline
Fairly common problem:
http://isuzufaq.ibctech.ca/#faq68
Serenity now!
Re: 4x4 engauge-99 3.5 [Re: three5] #932071 02/21/09 12:37 AM
bob large Offline
on the front axle there is a sleeve that slides to one side to bridge the split in the axle shafts. sometimes the two shafts are moving to fast or one is moving too fast (if you are drive the car) to allow the sleeve to slide across the splines of the shafts.
you can eliminate the problem by stopping the sleeve from moving at all. keeping it in the locked position.
another method to help it engage, is to push the 4x4 button and move ahead slowly. just creep ahead, sometimes you can actually hear it engage with a sharp click.
if its now working at all pull the cover off and let the engage arm hang down and push the button and see if the arm moves back and forth.
Steve C
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.5948 MB (Peak: 0.6477 MB) Data Comp: Off Server Time: 2026-11-02 21:48:08 UTC
