removing junk/glue on...... #932093 02/20/09 06:30 PM
F
flyinhawaiian Offline OP
howzit, was wondering the best and easiest way to remove the carpet glue on the cab floor. thanks.
Re: removing junk/glue on...... [Re: flyinhawaiian] #932094 02/20/09 11:43 PM
KiwiCowboy Offline
Acetone, but don't use it near fire or flame or smoking when you do it!
<img src="/forums/images/graemlins/scared.gif" alt="" />
Re: removing junk/glue on...... [Re: KiwiCowboy] #932095 02/21/09 01:13 AM
Stevie Offline
Methyl-ethel-ketone. Not sure where you can find MEK around here in California though <img src="/forums/images/graemlins/confused.gif" alt="" />.
'80 4X4 Longbed
Re: removing junk/glue on...... [Re: Stevie] #932096 02/21/09 03:35 AM
Vanishing_Point Offline
You can order it online. It's used to catalize certain fiberglass resins.
Re: removing junk/glue on...... [Re: Vanishing_Point] #932097 02/21/09 03:53 AM
4Crawler Offline
You can also get adhesive removers at most hardware stores. Goo Gone is one brand I have heard of (a citrus based solvent) and Goof Off (http://www.goof-off.com/) is one I recall using at one time. If tends to not be as aggressive and usually won't take off the paint like some of the stronger solvents may do. I've also used a citrus based paint stripper to remove decal adhesive on my hood and it worked really slick:
- http://www.4crawler.com/4x4/CheapTricks/Stripes.shtml
Re: removing junk/glue on...... [Re: flyinhawaiian] #932098 02/21/09 04:18 AM
Cholltero Offline
Go get a can of Permatex gasket remover. Methylene Chloride , that's the ticket. If you can't find that , go to Home Boy club and buy a can of Jasko or Jabro paint remover (sorry can't remember the exact name) same chemical. Works great (even for carbs) and smells good too. Water clean up , just don't get any onya, the amonium hydroxide that's in there will burn a little
Caution : Removes paint real well
85' 4x4 e-cab flatbed 22r carb ((SOLD))
86' 4runner, 22re , "60 buck truck"
95' 4runner, 22re,5sd, last of the good ones
02' Tacoma prerunner, 2.7L, 5spd., 4x4
Re: removing junk/glue on...... [Re: Cholltero] #932099 02/21/09 07:20 AM
F
2 many choices..... <img src="/forums/images/graemlins/confused.gif" alt="" /> nah, thanks guys appreciate the advise..aloha.
Re: removing junk/glue on...... [Re: flyinhawaiian] #932100 02/21/09 09:42 PM
wsquaredodie Offline
MEK is Nasty stuff but effective. Melts all kinds of plastics, including glues. Very volatile. Might want to try Brake Kleen as well, in a small area first. Methylene Chloride. Will do a dandy job but keep it away from cheap iron.
trafdlo
Re: removing junk/glue on...... [Re: wsquaredodie] #932101 02/22/09 06:04 AM
KiwiCowboy Offline
If using Methelene chloride, be sure to have plenty of ventilation unless you want to be a statistic.
<img src="/forums/images/graemlins/smile.gif" alt="" />
Re: removing junk/glue on...... [Re: KiwiCowboy] #932102 02/23/09 01:51 AM
OOP'S Offline
I used a heat gun and a putty knife to get the bulk of it off then MEK to get the rest off.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6296 MB (Peak: 0.7374 MB) Data Comp: Off Server Time: 2026-05-29 19:57:25 UTC
