Page 3 of 3 1 2 3
Re: getting ready for summer diving pt 2... [Re: off-roader] #932154 02/02/10 10:31 PM
Montero7081 Offline
35's?
oops... sorry yes 35x12.5x15 km2's <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
I can see how the 1996 is better than say a 1999 as the gear ratio is better for 35's at 4:61 (on '96) Compared to 4:21 (on 1999). Something to think about.
Re: getting ready for summer diving pt 2... [Re: Montero7081] #932155 02/02/10 10:35 PM
off-roader Offline OP
Aftermarket rims (15x8 or 15x10 w/ 4" of backspacing), a 2" BL, and torque the torsion bars. I still get slight rubbing up front inner fender well (not worried about this) and on the rear most part of the lower plastic body molding under the rocker panels. Hoping a 2" spacer from a Toyota Sequoia will fix that, but if not I know a sawzall will. <img src="/forums/images/graemlins/evil.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: getting ready for summer diving pt 2... [Re: off-roader] #932156 02/02/10 10:49 PM
Montero7081 Offline
I checked EBay. Didn't find a 2" BL. Safe to assume a different model is the same or you found someone who cares them?
How is the ride? I did the keys and torsion bar to my '04 Avalanche (before my suburban) and didn't like the ride after awhile. I did replace the shocks too with Bilstein 5100's. Did you replace the shocks?
Re: getting ready for summer diving pt 2... [Re: Montero7081] #932157 02/02/10 11:00 PM
hazy_daze Offline
Roger Brown makes the body lift or you can make it yourself. Think Ray has KYB's on his. I have the Bilsteins on my GenI. Either is an improvement unless you get one with the adjustables. If they're still in working order, they're the shizz.
Re: getting ready for summer diving pt 2... [Re: Montero7081] #932158 02/02/10 11:04 PM
For your first question, see the Body Lift thread in the How To section of the FAQ post for more details.
Ride's fine. Still using the stock 3 way adjustable shocks Mitsu had KYB build for them. Unfortunately the oem replacement will cost you your <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> if the originals wear out but nobody else makes a decent adjustable shock for the Montero.
When these wear out, I'll either replace them with OEM originals or a set of non-adjustable KYB's.
In terms of the torsion bars you can either get a set of stock bars from the dealer or used from a salvage yard or aftermarket from a variety of sources (ARB, SwayAway, etc.)
Re: getting ready for summer diving pt 2... [Re: off-roader] #932159 02/02/10 11:21 PM
Montero7081 Offline
Your a ton of information. Torsion bars in the front and coils in the rear I assume?
Electric hubs or manual hubs for 4x4?
Thanks
Re: getting ready for summer diving pt 2... [Re: Montero7081] #932160 02/02/10 11:37 PM
Thanks
Several reasons... Been here a while. 4th Montero. Bored at work. 4x4wire is addicting. (not necessarily in that order) <img src="/forums/images/graemlins/lol.gif" alt="" /> Bear in mind, I'm far from the sage here. There are many others that are WAY more technical and knowledgeable than I am on these rigs. You just haven't asked any 'hard' questions yet.
Yes.
No Hubs for the Gen 2/2.5
It has a Central Axle Disconnect (CAD) system. You can install manual hubs though to minimize wear on the front cv's/axles.
Re: getting ready for summer diving pt 2... [Re: off-roader] #932161 02/03/10 03:58 AM
0778drz110 Offline
Don't worry about the gears on the late 90s monteros...swap in 4.900 gears into most Gen2s from a late 1990s-2000ish Montero sport(different body style-google it)
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6330 MB (Peak: 0.7474 MB) Data Comp: Off Server Time: 2026-06-20 18:02:32 UTC
