91 pick-up shifter removal #932602 02/22/09 03:52 PM
huey Offline OP
OK Lads, I am going to start with the trans removal. I see how the transfer shifter comes out by removal of the snap ring but there is no such ring or screws for the trans shifter. The book states "Special Tool From Dealer". Please say it isn't so. Is there another way around this???? Thanks in advance.
Re: 91 pick-up shifter removal *DELETED* [Re: huey] #932603 02/22/09 04:47 PM
Adam F Offline
Post deleted by Adam F
97 4R, stock, daily driver
Re: 91 pick-up shifter removal [Re: Adam F] #932604 02/22/09 04:49 PM
Adam F Offline
Wait, your just doing this so you can remove the transmission? All you have to do is remove the 4 bolts holding the shifter plate to the tran (same with transfer) and the whole plate lifts off. No snap rings.
Re: 91 pick-up shifter removal [Re: Adam F] #932605 02/22/09 05:05 PM
huey Offline OP
Adam, just going by what the book says. The plate you refer to is the one that if removed also takes both levers with it?. Seems to me it opens up a big hole for dirt to fall into. Also, by removing the plate, are there any linkages inside that are going to get disturbed?. The last time I had to take a trans out it was a 3 speed colum shift.
Re: 91 pick-up shifter removal [Re: huey] #932606 02/22/09 05:22 PM
Adam F Offline
Yep, just remove the 4 bolts and lift off the entire shifter mechanism. It will leave a big hole in the trans, just cover it up somehow. I just stuff a rag in there. You could tape it up or something.
Linkages wont be disturbed. Put the levers in neutral and remove them. When you go to reinstall, just reinstall with the levers in neutral again.
Re: 91 pick-up shifter removal [Re: huey] #932607 02/22/09 08:11 PM
O
oldsub86 Offline
Am I missing something here? No need to remove the bolts and plate on my 4 Runner and I don't think I could with it in the truck without cutting the floor.
Just push down and turn the cup shaped doodad until it lines up with the lugs and lift the whole shifter out - like you would do if you were just changing the nylon parts in there.
Randy
1995 V6 SR5 5 speed 4X4 - 4Runner - dark blue
Re: 91 pick-up shifter removal [Re: oldsub86] #932608 02/23/09 02:14 AM
Adam F Offline
I always unbolted the shifter plate. But I do have a 3" body lift. Not sure if that makes it any easier.
Re: 91 pick-up shifter removal [Re: huey] #932609 02/24/09 07:15 PM
G
Greg_Canada Offline
If you just want to take out the arm, push that thing down and turn it counterclockwise a 1/4 turn. It's spring loaded. then it should pull right out.
89 4Runner
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6223 MB (Peak: 0.7201 MB) Data Comp: Off Server Time: 2026-07-16 03:40:57 UTC
