89 XJ WITH INJECTOR PROBLEMS #933026 02/24/09 04:09 PM
5
54539 Offline OP
I have a 89xj 4.0 needs work.I needed to replace leaking injectors.I heard that it was ok to use ford injectors.So I attempted to use 6 ford 24# injectors (free). Now It will not start. I have spark and fuel in the rail.Any suggestions will be very helpful.
Re: 89 XJ WITH INJECTOR PROBLEMS [Re: 54539] #933027 02/24/09 04:37 PM
BigJim Offline
I donno nothin bout them ford injectors... But I do know to squirt some fuel (any type) into the TB to see if it is a fuel problem OR a lectric problem..If it sputters from the fuel you squirt in there it is a fuel problem, if not it is lectric.. do that and get back here with the results.
Re: 89 XJ WITH INJECTOR PROBLEMS [Re: BigJim] #933028 02/24/09 04:47 PM
5
54539 Offline OP
Yeah I did that,and I did get a sputter.
Re: 89 XJ WITH INJECTOR PROBLEMS [Re: BigJim] #933029 02/24/09 04:49 PM
5
54539 Offline OP
Could it be electrical problem with injectors?
Re: 89 XJ WITH INJECTOR PROBLEMS [Re: 54539] #933030 02/24/09 05:02 PM
BigJim Offline
Ok then Houston we have a problem...with the injectors (FORD)! I think I'd be for putting a couple of MOPAR ones back in there and see if I got a sputter out of the few I replaced.. If so then I'd be thinking the Ford ones weren't compatable.
Re: 89 XJ WITH INJECTOR PROBLEMS [Re: BigJim] #933031 02/24/09 05:05 PM
BigJim Offline
I don't really know enough bout injectors to even be posting in this thread...but that said I'm thinking the injector is looking for a certain voltage and a certain fuel pressure..and the ford ones ain't getting one or the other.
Re: 89 XJ WITH INJECTOR PROBLEMS [Re: BigJim] #933032 02/24/09 05:32 PM
5
54539 Offline OP
OK so I was being cheap, going to clean up old injectors and put new o-rings on and see what happens.I waiting for my stimulus LOL
Re: 89 XJ WITH INJECTOR PROBLEMS [Re: BigJim] #933033 02/25/09 07:27 AM
5
54539 Offline OP
running! removed fomoco injectors put in used mopars and cleaned them first . ran like a charm. ford injectors would not open
Re: 89 XJ WITH INJECTOR PROBLEMS [Re: 54539] #933034 02/25/09 04:52 PM
BigJim Offline
So now we all know! What else would you like to be the first to try?
Re: 89 XJ WITH INJECTOR PROBLEMS [Re: 54539] #933035 03/01/09 08:28 PM
Berkeley Offline
Jeep Moderator
Lots of the SoCalXJ guys run Ford 5.0 injectors. Not for performance... only 'cause parts for the 5.0 are cheaper. They buy from here: http://www.fiveomotorsport.com/
IIRC, 19lb works for an unmodified 4.0 engine. There are a number of 19lb choices, however, and I don't remember the part number.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6331 MB (Peak: 0.7403 MB) Data Comp: Off Server Time: 2026-06-20 18:15:59 UTC
