89 XJ WITH INJECTOR PROBLEMS
#933026
02/24/09 04:09 PM
I have a 89xj 4.0 needs work.I needed to replace leaking injectors.I heard that it was ok to use ford injectors.So I attempted to use 6 ford 24# injectors (free). Now It will not start. I have spark and fuel in the rail.Any suggestions will be very helpful.
Re: 89 XJ WITH INJECTOR PROBLEMS
[Re: 54539]
#933027
02/24/09 04:37 PM
I donno nothin bout them ford injectors... But I do know to squirt some fuel (any type) into the TB to see if it is a fuel problem OR a lectric problem..If it sputters from the fuel you squirt in there it is a fuel problem, if not it is lectric.. do that and get back here with the results. Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#933028
02/24/09 04:47 PM
Yeah I did that,and I did get a sputter.
[Re: BigJim]
#933029
02/24/09 04:49 PM
Could it be electrical problem with injectors?
[Re: 54539]
#933030
02/24/09 05:02 PM
Ok then Houston we have a problem...with the injectors (FORD)! I think I'd be for putting a couple of MOPAR ones back in there and see if I got a sputter out of the few I replaced.. If so then I'd be thinking the Ford ones weren't compatable. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#933031
02/24/09 05:05 PM
I don't really know enough bout injectors to even be posting in this thread...but that said I'm thinking the injector is looking for a certain voltage and a certain fuel pressure..and the ford ones ain't getting one or the other. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#933032
02/24/09 05:32 PM
OK so I was being cheap, going to clean up old injectors and put new o-rings on and see what happens.I waiting for my stimulus LOL
[Re: BigJim]
#933033
02/25/09 07:27 AM
running! removed fomoco injectors put in used mopars and cleaned them first . ran like a charm. ford injectors would not open
[Re: 54539]
#933034
02/25/09 04:52 PM
running! removed fomoco injectors put in used mopars and cleaned them first . ran like a charm. ford injectors would not open So now we all know! What else would you like to be the first to try? Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: 54539]
#933035
03/01/09 08:28 PM
Jeep Moderator
Lots of the SoCalXJ guys run Ford 5.0 injectors. Not for performance... only 'cause parts for the 5.0 are cheaper. They buy from here: http://www.fiveomotorsport.com/ IIRC, 19lb works for an unmodified 4.0 engine. There are a number of 19lb choices, however, and I don't remember the part number.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6350 MB (Peak: 0.7422 MB) Data Comp: Off Server Time: 2026-06-21 20:21:40 UTCValid HTML 5 and Valid CSS
