Anyone know the specs of a 9" diff
#933055
02/24/09 08:32 PM
I need to know the distance on the third member chunk between the plane which gets mounted to the face of the axle housing to the center of the carrier.
Anyone? Or any ideas of where to find this info? I have a 9" diff but i don't have the carrier. I estimate its a little over 1.5" but id like the exact number if anyone knows it.
Thanks.
Welding and Fabrication Engineer 2003 taco V6 ext cab sr5 1988 Toyota Pickup V6(totaled)
Re: Anyone know the specs of a 9" diff
[Re: CraShYota]
#933056
02/24/09 09:45 PM
[Re: sparkem]
#933057
02/24/09 11:07 PM
ford 9". sorry i didn't know there was another 9".
[Re: CraShYota]
#933058
02/25/09 12:52 AM
That is what I figured, but if it was a Mitsu one I could get a measurement for you.
[Re: sparkem]
#933059
02/25/09 01:39 AM
I measured it as 1 23/32". but i measured assuming that where the chunk splits to hold the carrier is halfway and therefore the center. Hope its right. I'm designing/building a 9/60 moly housing. this may end up being the worst ***** show in the world. lmao. if there is a gap just fill it with weld right?
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6062 MB (Peak: 0.6701 MB) Data Comp: Off Server Time: 2026-11-02 12:25:56 UTCValid HTML 5 and Valid CSS
