'97 sportage toyota solid axle swap #934156 03/05/09 05:31 AM
scookkay Offline OP
getting parts together for solid axle swap on my kia i just got. using toyota axles front and rear. will post pics of build, if anyone is interested.
Re: '97 sportage toyota solid axle swap [Re: scookkay] #934157 03/13/09 04:07 PM
V
victwisted Offline
Yes lets take a look at that,good luck <img src="/forums/images/graemlins/kewl.gif" alt="" />
99' sportage,4"lift RSG,31" M/T Baja MTZ on DC1 rims,custom 1 3/4" body lift, one dog,one cooler,one heavy foot,maps, and the will to wheel my kia with the rest of the offroad world
Re: '97 sportage toyota solid axle swap [Re: victwisted] #934158 03/14/09 12:07 AM
DEFBOY35 Offline
whats your plans for doing the swap.
i should be starting mine hopefully in the next week or so.
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
Re: '97 sportage toyota solid axle swap [Re: scookkay] #934159 03/14/09 12:37 AM
DennisThompson Offline
If you look up threads for KIAFREEKROB here on the wire he has Toyota axles on his, Dave Scott has Scout D44s on his. You could get some good ideas on Them. Keep us posted and send lots of pics. When the times is right I want to do a SAS also, I have Jeep Wagoneer/Cherekee D44s that I might use. The only problem is the rear has a right side offset dif like the front.
Dennis
Re: '97 sportage toyota solid axle swap [Re: DennisThompson] #934160 03/15/09 04:02 AM
scookkay Offline OP
going to redo 4 link in rear to double triangulated four link, and 3 link the front. going to keep coil sprigs for now. hope to go swayaway air shocks in the near future.
Re: '97 sportage toyota solid axle swap [Re: scookkay] #934161 03/15/09 08:50 PM
Dave Scott Offline
always interested. spend time on the design. build it like you mean it. that is all...
Re: '97 sportage toyota solid axle swap [Re: victwisted] #934162 03/25/09 11:41 PM
Hydra747 Offline
x2 <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6170 MB (Peak: 0.6908 MB) Data Comp: Off Server Time: 2026-06-10 07:26:20 UTC
