Replacement AX-5 not fitting #934328 03/06/09 03:12 AM
Madcat Offline OP
Last year blew I out the tranny in my '93 Cherokee. Finally got around to replacing it and now it won't fit properly. The transfer case is sitting too high, and the front driveshaft is hitting the 4WD linkages. The tranny crossmember/mount is installed correctly, I even tried dropping the crossmember with spacer plates I made and its still hitting. Does anyone have any ideas.
Jim
1979 Pontiac Trans-Am - looking 4 a pontiac 455cid
1988 Trooper II - AMC head, .030 overbore, Calmini cam. Toga HV oil pump, Aisins, soon 2 b turbo
1989 Impulse Turbo - Fidanza flywheel, 270cc injectors, turbo-back exhaust, KYBs F/R
Re: Replacement AX-5 not fitting [Re: Madcat] #934329 03/06/09 03:46 AM
BigJim Offline
When you look at it does it look like maybe if you turned the Xmember upside down it would fit better?
Re: Replacement AX-5 not fitting [Re: BigJim] #934330 03/06/09 11:20 PM
Madcat Offline OP
I wish it was something that simple.
Anyone else have any clues???
Jim
Re: Replacement AX-5 not fitting [Re: Madcat] #934331 03/20/09 12:24 PM
Brown81CJ5 Offline
If it has the 4.0L I believe it would need an AX-15, not an AX-5.... Cherokee info
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: Replacement AX-5 not fitting [Re: Brown81CJ5] #934332 03/21/09 02:07 AM
Madcat Offline OP
Nope its the 2.5L with the AX-5.
I just cut out all the factory levers/shafts and made my own handle/lever out of an old shifter I had laying around.
Push it towards the dash and down - 4WD
Pull it back and up - 2WD
Jim
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6043 MB (Peak: 0.6683 MB) Data Comp: Off Server Time: 2026-07-09 15:23:35 UTC
