Roof racking the genII LWB using gutter mounts - do we HAVE to use the higher foot? #934344 03/06/09 04:00 AM
PHIL_ Offline OP
Tried the fit guide, and Thule recommended the "high" foot. Anyone using the standard foot? I measured 5 inches from the channel to the roofline, which is what the standard foot says it clears the gutter by. Even if it fits, I worry that slight sag in the load bar would mean roof contact...
Re: Roof racking the genII LWB using gutter mounts - do we HAVE to use the higher foot? [Re: PHIL_] #934345 03/08/09 08:02 PM
PHIL_ Offline OP
Anyone mounted a Thule/Sportrack/Yakima etc. that can answer this for me, on a genII? Just want to know if I need the higher gutter mount feet to cleat that huge roof on the back. I'd rather use the standard height ones, otherwise the front will be way up there...
Re: Roof racking the genII LWB using gutter mounts - do we HAVE to use the higher foot? [Re: PHIL_] #934346 03/08/09 08:06 PM
Yakima recommends the std foot for gen II's. It recommends the taller foot for Gen I's. I used the stndrd foot for both. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Not sure about Thule.
Don't forget though. Both will get snagged easily on brush off road much more so than the OE rack if you have that option in Betsy. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Roof racking the genII LWB using gutter mounts - do we HAVE to use the higher foot? [Re: PHIL_] #934347 03/08/09 08:20 PM
I use a standard Thule up front with the cross bar attached with custom steel brackets in the rear.
Some loads may be carried better with the tall fronts.
Re: Roof racking the genII LWB using gutter mounts - do we HAVE to use the higher foot? [Re: OldColt] #934348 03/08/09 08:30 PM
Standard Yaks on my 95. I had an OEM rack, so I have the rubber bumpers on the roof ribs. The back bar touches the bumpers and presses down oh so very slightly on the roof. Nothing at all like it's denting it, and I much prefer the lower sitting point.
Re: Roof racking the genII LWB using gutter mounts - do we HAVE to use the higher foot? [Re: off-roader] #934349 03/08/09 08:40 PM
PHIL_ Offline OP
I had a Terzo on Betsy one through three, so I'm not too worried about snagging (although I did hit a low hanging branch hard enough one time to pull the rack and basket off the roof and onto the trail behind me!! <img src="/forums/images/graemlins/lol.gif" alt="" />) - I couldn't put one on Betsy4 because of the lack of gutters. Now I have gutters again (but no factory rack), so I'm just gonna rack it again with some form of multi-system. Nice to know I can fit a standard one though. Wasn't sure if it was higher than my genI roof or not - nice to know it isn't... <img src="/forums/images/graemlins/kewl.gif" alt="" /> Thanks fellas.
Re: Roof racking the genII LWB using gutter mounts - do we HAVE to use the higher foot? [Re: PHIL_] #934350 03/22/09 07:25 PM
PHIL_ Offline OP
Just to update, I found a Terzo roofrack on Kijiji, called about it, and then went and picked it up (real good price!). Almost identical to the one I had on BetsyI-III. Japanese manufacturer too, so appropriate. <img src="/forums/images/graemlins/smile.gif" alt="" />
Like this:
Between myself and mitsulvr (Betsy III's current owner) we beat the old Terzo rack up pretty good (low branches and stuff), but there's enough bits left to make one more good bar, so with the long roof on Betsy V, I'll have three bars. Now I need to find a basket...
Re: Roof racking the genII LWB using gutter mounts - do we HAVE to use the higher foot? [Re: PHIL_] #934351 03/22/09 10:13 PM
jwp Offline
Hi, I hope I am not hijacking this thread but I went through the whole Thule experience last summer - wondering which one fits. Thule told me to "use the tall one". I didn't believe them at first but they are right. It is really high but my rack sits down in between the rails about half-way. If you want to use the rack on the highway at 60+, you will want a windscreen - the buffeting gets sever with just the rack alone. If you have canoes on it, disregard.
The windscreen must be stiff or it buffets. I used 6061 AL cut on a water-jet. It is VERY quiet and even with it loaded. I hardy know it is up there at 70+. While we were making the CAD file, we added the diamond-star logo. I used 1" sq tubing with 1/8" wall. There is one support down the middle and 1/8" x 1" expanded metal for the floor. I can easily stand on the rack with very little deflection and use it sometimes use it as a shooting platform for rock-chucks if the wind isn't blowing too much. I guess I could have thrown a couple of chairs on if for our annual Spokane St Patrick's day parade. There is about 1/2" between the ridge of the roof and the bottom of the rack rail.
I hope this helps. Cheers, Jeff
[img]http://i188.photobucket.com/albums/z310/jkpugh65/DSCF0005-2.jpg[/img]
[img]http://i188.photobucket.com/albums/z310/jkpugh65/DSCF0006-2.jpg[/img]
[img]http://i188.photobucket.com/albums/z310/jkpugh65/DSCF0008-1.jpg[/img]
1991 LWB Montero LS 213kmi - original. Stock.
2003 LWB Montero LTD 95kmi - original. All leather, stock and sweet
----Drive it like you have to use it to get to work in the morning.----
Re: Roof racking the genII LWB using gutter mounts - do we HAVE to use the higher foot? [Re: PHIL_] #934352 03/23/09 02:30 AM
L
lites1995 Offline
For the Yakima fit, here's what I did when we had the '98. I couldn't find a single picture of my rig to help illustrate what I'm talking about though.
You can get by with the regular tower, but if you are mounting toward the rear you may not have much clearance between the rear cross bar and roof. That made it difficult for me to mount many of the Yakima accessories. Probably OK if you are planning to mount a cargo basket with u-bolts though.
On the '98 I took off the factory rack. I already had the Yakima 1A towers so I purchased the hi rise kit which is basically the spacers and additional hardware you get if you buy the hi rise towers as a package. I cut the hi rise spacers down so the rack didn't look so freakish and the crossbars sat closer to the roof. If you go this route you have to replace or shorten the bolts that run (vertically) through the spacer. Hope that all makes sense.
Not that I ever had a problem with the Yakima (it is still going strong on the '89), but if you are going to put a cargo rack up there and load it down, I like the Thule towers because they are one solid piece of metal vs the composite yakima tower.
'89 LWB, V6, Auto, 31" BFG AT, ARB Locker, ARB Bumper, Aisin Manual Hubs, Dual Bouncy Seats
Re: Roof racking the genII LWB using gutter mounts - do we HAVE to use the higher foot? [Re: jwp] #934353 03/23/09 05:20 AM
Oyaji_Jon Offline
Nice job on that rack. Functional period...
You need to make a thread and spill the beans on those bumpers, though...
Congrats on the find, Phil. It's always nice to get exactly what you want sometimes!
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6540 MB (Peak: 0.7803 MB) Data Comp: Off Server Time: 2026-06-07 11:33:21 UTC
