toyota courier #934811 03/07/09 09:07 PM
gueroblanco Offline OP
anyone have any idea how much of the wiring in an 85 is essential if the stock carburetor setup is done away with? I just scored a '75 ford courier <img src="/forums/images/graemlins/barf.gif" alt="" /> and plan on using it for its body and therefore keeping everything i like about my yota except the ca smogging difficulties. i'm thinking about using a webber carb and eliminating all non- essential wiring in the swap. Any ideas are welcome.
'95 runner 3vze/r150f
Re: toyota courier [Re: gueroblanco] #934812 03/08/09 01:10 AM
Snowtoy Offline
A lot of work just to avoid a smog check every two years. Also isn't the Currier a smaller truck?
If you want to build a Currier into a 4x4, that would be a different/one-off kind of rig, and you wouldn't be turning an '85 Toy into a '75 Ford.
I haven't checked but are you only 3-6yrs(27 or 30 yrs old car) from no more smog checks, or have they reversed the 27yr date again.
Re: toyota courier [Re: Snowtoy] #934813 03/08/09 03:07 AM
I think they stopped the rolling date at 75 or 76. and yes it is a bit smaller but not much. the engine compartment is 2 inches shorter longitudinally and about the same in width difference as well. the cab is just slightly smaller too maybe an inch. it is a lot of work, I'm just trying to work with what is available to me and I want the freedom to mess with stuff under the hood and be able to drive on the street legally still.
Re: toyota courier [Re: gueroblanco] #934814 03/08/09 04:36 AM
Snowtoy Offline
I understand the desire to escape CARB, but you would still have to smog it if and when you sold it.
I wouldn't cut up the '85 though, I would look for an IFS rig that is being parted out, similar to these, 1986 Toyota 4x4 22RET, parting out 86 toyota 4x4, Parting out 1988 toyota 4 runner, then throw a Dana 44 under the front. In the long run it would probably cost you less than what you could get for your '85.
Re: toyota courier [Re: Snowtoy] #934815 03/08/09 06:35 AM
A
ak92toyota Offline
go to fordcouriercollector.com theres someone there doing this swap with a 73 courier body and a toyota pickup frame/running gear
Re: toyota courier [Re: ak92toyota] #934816 03/09/09 01:03 PM
I've never had to smog anything that was beyond the smog age threshhold, no way, no how, not even when selling. Not that I would ever want to sell this frankenstien monster that I'm thinkin about building. <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: toyota courier [Re: ak92toyota] #934817 03/09/09 01:09 PM
go to www.fordcouriercollector.com theres someone there doing this swap with a 73 courier body and a toyota pickup frame/running gear
I could not find the thread you referenced.
Re: toyota courier [Re: gueroblanco] #934818 03/09/09 11:10 PM
A
ak92toyota Offline
it is under general discussion called earlkanns saaquatch buildup
Re: toyota courier [Re: ak92toyota] #934819 03/10/09 12:43 AM
thanks i'll check it out.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6264 MB (Peak: 0.7293 MB) Data Comp: Off Server Time: 2026-06-17 10:42:34 UTC
