Suspension Lift + Coil Spacers = Good or Bad Idea? #935351 03/11/09 04:08 PM
G
Guntero Offline OP
I want to achieve a 3"-4" lift on my Gen III. Is it safely feasible to combine the OME 2" suspension lift with a 1" or 2" coil spacer?
Is this a good or bad idea? Thoughts please.
Thanks
Guntero (died in battle)
1995 Montero LS - Matte Black
265/75R16 BFG All-Terrains
Guntero (current)
2001 Montero Limited - Gold
OME HD Lift
285/75R16 BFG All-Terrains
Re: Suspension Lift + Coil Spacers = Good or Bad Idea? [Re: Guntero] #935352 03/11/09 04:18 PM
You'll probably have issues with your CV joints. You'd be better off doing a combination suspension lift, plus a 'body lift' to the front and rear drivetrain assemblies. As I understand it, they sit on their own subframe which can be lifted like you would a body lift. Not sure if you could use standard body lift type pucks or if you would have to fabricate something special for the gen III IFS subframe setup.
Re: Suspension Lift + Coil Spacers = Good or Bad Idea? [Re: Guntero] #935353 03/11/09 04:18 PM
hazy_daze Offline
Thought you had a GenII? Or is that a typo?
Re: Suspension Lift + Coil Spacers = Good or Bad Idea? [Re: hazy_daze] #935354 03/11/09 04:21 PM
G
Guntero Offline OP
I bought a Gen III a couple weeks ago, not a typo.
Guntero (current)
OME HD Lift
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6015 MB (Peak: 0.6570 MB) Data Comp: Off Server Time: 2026-06-07 04:51:32 UTC
