Page 2 of 4 1 2 3 4
Re: Oh no, strached my crank - can't believe it [Re: vr4] #935367 03/11/09 08:59 PM
sparkem Offline
What would The Stig do?
Re: Oh no, strached my crank - can't believe it [Re: sparkem] #935368 03/11/09 09:12 PM
Mad_Scientist Offline OP
Thanks fellas. Will do as you suggest Charlie, re seal lip. Fingers crossed.
<img src="/forums/images/graemlins/lol.gif" alt="" /> That brought a smile to my face for the first time in a few hours! WWSD? For the record The Stig said sh!!!!!!!!t <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Oh no, strached my crank - can't believe it [Re: Mad_Scientist] #935369 03/12/09 12:54 AM
KrzyDav Offline
I did that ,,,,so I didn't want to take a chance with such an important seal..
Get a Speedy Sleeve, <img src="/forums/images/graemlins/kewl.gif" alt="" /> ( buy 2 for the one you mess up).
$18.00 at Kragen.
I used a crank bolt and a socket to Slowly press it on. I did not used sleeve retainer glue.
Mines 2 years old.
dave h.
Re: Oh no, strached my crank - can't believe it [Re: KrzyDav] #935370 03/12/09 02:12 PM
raiderquest Offline
Speedy sleeves will slide right on if warmed up in the oven first....
Re: Oh no, strached my crank - can't believe it [Re: raiderquest] #935371 03/12/09 07:16 PM
Never heard of these sleeves, though I get what they are about. Are they then thin enough and/or the seal has enough stretch that the OEM seal still works? ot do you have to get a larger I.D. seal?
Re: Oh no, strached my crank - can't believe it [Re: MontyMcV] #935372 03/12/09 08:18 PM
raiderquest Offline
Speedy sleeves are made of stainless steel. I have used them on harmonic balancer snouts and even on spindels after a bearing has siezed and made it unfit to put a new bearing on. They are thin enough that stock seals still work perfectly and the stainless is strong enough to apply pressure to install them.They have a removable flange on one end that lets you drive them on. I have always heated the sleeve and if possible, put the other part (harmonic balancer) in the freezer. Heat/cold works like magic.
Speedy sleeves are a life saver in some cases.
Re: Oh no, strached my crank - can't believe it [Re: raiderquest] #935373 03/12/09 09:44 PM
Amen to that <img src="/forums/images/graemlins/kewl.gif" alt="" />
All back together and running like a champ...apart from some minor idle issues. I hope the crank seal will be OK. Only time will tell I guess. I'd rather not see the timing belt on this truck for quite a while <img src="/forums/images/graemlins/baby.gif" alt="" /> Besides, I can't afford it <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Phew! That was a marathon!! More the valve guide seals later...
Re: Oh no, strached my crank - can't believe it [Re: Mad_Scientist] #935374 03/12/09 09:56 PM
hazy_daze Offline
Glad it's back together Reuben <img src="/forums/images/graemlins/kewl.gif" alt="" />
You should be fine.
'Cause you're the Stig, right? <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Oh no, strached my crank - can't believe it [Re: hazy_daze] #935375 03/12/09 10:58 PM
sparkem Offline
Yes he is.
Re: Oh no, strached my crank - can't believe it [Re: sparkem] #935376 03/13/09 12:19 AM
V
vr4 Offline
if you dont have any leaks in the next week or so you should be ok
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6435 MB (Peak: 0.7685 MB) Data Comp: Off Server Time: 2026-06-07 06:10:37 UTC
