Anyone installed a Double-DIN radio in a GenIII? #935665 03/13/09 07:08 PM
G
Guntero Offline OP
Similar to this:
Are there any known grievances with replacing the factory Infinity Radio?
Thanks
Guntero (died in battle)
1995 Montero LS - Matte Black
265/75R16 BFG All-Terrains
Guntero (current)
2001 Montero Limited - Gold
OME HD Lift
285/75R16 BFG All-Terrains
Re: Anyone installed a Double-DIN radio in a GenIII? [Re: Guntero] #935666 03/15/09 12:59 AM
lordtrunks Offline
The system is factory amped there is a kit that will give you rca connectors to plug into your new head unit or you need to find and unplug and remove the factory amp the connect where the amp is, which will may still need a kit to extend wires if its not close.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: Anyone installed a Double-DIN radio in a GenIII? [Re: lordtrunks] #935667 03/15/09 01:03 AM
lordtrunks Offline
Ok here is the metra part number for the harness to the factory amp to your new stereo 70-7003
Re: Anyone installed a Double-DIN radio in a GenIII? [Re: lordtrunks] #935668 03/15/09 08:40 PM
G
Guntero Offline OP
Thanks Lordtrunks..much appreciated.
Guntero (current)
OME HD Lift
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6020 MB (Peak: 0.6578 MB) Data Comp: Off Server Time: 2026-06-07 01:36:47 UTC
