Anyone installed a Double-DIN radio in a GenIII?
#935665
03/13/09 07:08 PM
Similar to this: Are there any known grievances with replacing the factory Infinity Radio? Thanks
Guntero (died in battle) 1995 Montero LS - Matte Black 265/75R16 BFG All-Terrains
Guntero (current) 2001 Montero Limited - Gold OME HD Lift 285/75R16 BFG All-Terrains
Re: Anyone installed a Double-DIN radio in a GenIII?
[Re: Guntero]
#935666
03/15/09 12:59 AM
The system is factory amped there is a kit that will give you rca connectors to plug into your new head unit or you need to find and unplug and remove the factory amp the connect where the amp is, which will may still need a kit to extend wires if its not close.
89 2 dr turbo diesel 89/88 "Backwoods sas"
[Re: lordtrunks]
#935667
03/15/09 01:03 AM
Ok here is the metra part number for the harness to the factory amp to your new stereo 70-7003
[Re: lordtrunks]
#935668
03/15/09 08:40 PM
Thanks Lordtrunks..much appreciated.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6020 MB (Peak: 0.6578 MB) Data Comp: Off Server Time: 2026-06-07 02:21:32 UTCValid HTML 5 and Valid CSS
