cranks but wont fire!!! #935701 03/14/09 08:38 AM
riding4him Offline OP
My 1991 isuzu trooper 2.8 V6 4x4 automatic will crank and it is getting gas but wont start. What would be the best things to check out first? Any help will be appreciated. Thanx.
Re: cranks but wont fire!!! [Re: riding4him] #935702 03/14/09 12:56 PM
Jim_Paget Offline
The old truth is that you need three things for ignition - spark, fuel, and air (all at the correct time, of course).
If this was a running engine, and now has this problem, I would start with the primary wiring - distributor, coil, coil wire, plug wires and plugs.
If the engine has been out and you are now trying to start it, you are going to have to tell us more about what you have done.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: cranks but wont fire!!! [Re: Jim_Paget] #935703 03/14/09 05:20 PM
It was running in my other trooper but i put it in my nicer one with power window, auto trooper now. i have everything hookd up i guess ill just check the ignition system. Thanx alot. I have done a couple motor swaps before and i know it is hard to work out the final kinks.
Re: cranks but wont fire!!! [Re: riding4him] #935704 03/20/09 08:03 PM
Put in new NGK sparkplugs started right up!! Runs Great!!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6005 MB (Peak: 0.6558 MB) Data Comp: Off Server Time: 2026-06-07 04:20:52 UTC
