More Questions on a 2wd/4wd Frame Difference- URGENT!
#936102
03/16/09 07:33 PM
I'm going to look at a '85 2wd xtra cab truck as a possible donor for a 4wd project. My urgent question is about a tow bar that I made to tow 4wd trucks and 4runners ('84 - '88). I made some tabs that bolt to the front of the frame on the bottom of each frame rail where factory attaches the "recovery" hook. I bolt these tabs onto the truck to be towed using factory mounting points. Then I attach my tow bar to these tabs. I've only used this on 4wd rigs. Do 2wd trucks have the same "recovery hook" mounting points on the frame? -- Matt ![[Linked Image]](http://www.wrenchtech.com/pichost/TowTab.jpg)
'89 4runner SR5, 3.0, auto (fun) '93 xtra cab, dlx,3.0, 5spd (work truck)
Re: More Questions on a 2wd/4wd Frame Difference- URGENT!
[Re: matts]
#936103
03/16/09 09:23 PM
I think it's probably too different. My tow bar is not adjustable (something I should fix). I'll probably rent a tow dolly. -- Matts
[Re: matts]
#936104
03/16/09 09:46 PM
The 2wd's have 2 tow tabs instead of one hook and one tab. I would think they would be the same bolt pattern, since it would keep productin costs down, but I am not 100% positive.
[Re: Snowtoy]
#936105
03/16/09 11:09 PM
I think they are different, although if I got off my arse, I could look at my own. <img src="/forums/images/graemlins/cyclops.gif" alt="" /> The front bumper mounts are completely different on the frame side of a 2wd, but the actual factory bumper is the same piece (except for the bumper end caps). I'll see if I can locate the mount points you're referring to on my truck.
EDIT - take a look at the pic in your other thread, if it helps.
Todd
1986 Pickup extracab longbed "Woody edition" SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD" 94 2wd v6 extracab 04 Outback Wagon- wife's/family car
[Re: Elbow_Greese]
#936106
03/16/09 11:37 PM
Well, this picture may not be worth a thousand words, but it should give you your answer. <img src="/forums/images/graemlins/notooth.gif" alt="" /> Todd
[Re: Elbow_Greese]
#936107
03/17/09 12:41 AM
As stated the 2wds have 2 loops instead of a loop and hook but the mounting holes are the same. I switched to an '86 2wd frame and swaped the hook over.
[Re: Vanishing_Point]
#936108
03/17/09 04:26 AM
When I went to look at the 2wd truck I checked those tabs and they seemed to spaced about a 1/2" farther apart (25" vs 24-5/8") rail to rail, but it looks like the bolt spacings for mounting are the same. I think my tow bar would work with this. Unfortunately the truck I looked at was totally misrepresented. It was said to have a good cab and frame but it turned out to have big rust holes on the rockers and a big hole in the frame next to the gas tank. <img src="/forums/images/graemlins/frown.gif" alt="" />
Thanks to all who tried to help out. -- Matt
[Re: matts]
#936109
03/17/09 11:01 PM
I love your cookie-based front cross-member!!! <img src="/forums/images/graemlins/baby.gif" alt="" />
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/ Camper/33x10.5BFG-AT/Open 4:88/1.5"BJS/ +2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
