1997 Jeep Grand Cherokee: A/C compressor constantly engages then dis-engages #936453 03/19/09 12:18 AM
mattd Offline OP
This is the second problem with my Jeep. It started last summer, my A/C compressor is constantly engaging then dis-engaging. It did this throughout the entire winter and is killing my fuel consumption. What is the problem?
Thanks
Re: 1997 Jeep Grand Cherokee: A/C compressor constantly engages then dis-engages [Re: mattd] #936454 03/19/09 02:04 AM
BigJim Offline
First off the compressor comes on when the DEFROST is used..
That should explain the winter use.
Now if it comes on and off more than expected usually the cause is LOW freon. You might need a touch added.
Big Jim
Re: 1997 Jeep Grand Cherokee: A/C compressor constantly engages then dis-engages [Re: BigJim] #936455 03/19/09 03:35 AM
cuervo25 Offline
Have a shop do it,they can add dye in with the freon to detect leaks. take it back a few days later and they will use a uv light to find where the leaks may be.It is possible but very remote that your refridgerant is just old and need to be recycled but more likely at that age there is a leak.
Re: 1997 Jeep Grand Cherokee: A/C compressor constantly engages then dis-engages [Re: mattd] #936456 03/19/09 10:51 PM
mattd Offline OP
I was actually going to buy a freon kit to fill up my A/C, I have a small leak and it needs filling every few years.
Thanks,
Re: 1997 Jeep Grand Cherokee: A/C compressor constantly engages then dis-engages [Re: mattd] #936457 03/19/09 11:06 PM
reepersteve Offline
Sorry to tell yah, freon does not get old. Don't let a tech tell you that.
just my 2<.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6051 MB (Peak: 0.6690 MB) Data Comp: Off Server Time: 2026-10-22 12:16:11 UTC
