89 Raider engine just stops then after a while will restart #936463 03/19/09 03:53 AM
JimskyD Offline OP
I've got an 89 Raider that I love. For the last few months it will just stop dead. Still cranks but nothing happening under the hood. Have replaced the ignitor. I continually monitor the ECU now and it shows no problem when it stops then, after a few hours, will show code 22 & 23 (TDC sensor). No smell of gas after extensive cranking. After some time (five min but more like 1 hour) it will restart.
I know I've found something in the forum here about that but cannot seem to locate it.
Any ideas or suggestions?
Thanks,
Jim in Seattle
Re: 89 Raider engine just stops then after a while will restart [Re: JimskyD] #936464 03/19/09 07:28 AM
#1 Coil
#2 Power unit
#3 fuel pump
my guesses <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: 89 Raider engine just stops then after a while will restart [Re: TOASTY] #936465 03/19/09 05:13 PM
8
89IsMine Offline
Sounds a bit like my fuel pump before it died completely, although I never had any codes show, so quite possibly its an electrical issue. If you don't have it, go snag the PowerTrainDiagnostics manual here: manuals, etc.
It has the no-start and driveability tests in it, and should help you diagnose this issue. If you want to read about what my fuel pump was doing, do a user search on my user name (89IsMine), sometime back around November 2006.
Good luck <img src="/forums/images/graemlins/kewl.gif" alt="" />
Eric W.
Re: 89 Raider engine just stops then after a while will restart [Re: 89IsMine] #936466 03/19/09 05:37 PM
jrowe Offline
My 89 did the same exact thing. It turned out to be 2 problems. I had a bad power unit and a bad photo optic sensing unit (in the distributor). The connector on the power unit has caused this problem as well.
Re: 89 Raider engine just stops then after a while will restart [Re: jrowe] #936467 03/19/09 05:51 PM
FrankR Offline
When was the fuel filter last changed?
A TDC sensor code can mean the optical sensor in the distributor is bad, but I'm curious about the fuel filter.
Frank
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6064 MB (Peak: 0.6713 MB) Data Comp: Off Server Time: 2026-06-10 07:17:50 UTC
