No Start #936663 03/20/09 08:10 PM
dylanb Offline OP
Ok, so a few months back the 4d55 I swapped into my truck seemed to blow a head gasket. I slowly got parts and went to fixing it between school and work on the weekends, and finally got it all back together about a week ago.
For some reason I cannot get the thing to run for the life of me. It turns over, seems like it wants to catch, but never does. I have checked everything I know to.
-Ran the fuel pump for a few minutes and purged the lines to make sure there was no air in them.
-Fuel is getting to the injector pump at the very least. I can hear the fuel cut solenoid in the injector pump cycle. --Tested glow plugs and swapped them for a used set I had laying around - they seem to be working.
-Checked the timing to make sure everything was right several times.
-Checked valve clearances - I only have clearance specs for a hot engine, so i figured I would add about two thousandths of an inch extra on the cold measurement - I think they are set at .013 where the hot spec is .011.
Not really sure what else to do here, and I really want to get my baby back on the road. Any advice or tips would be very greatly appreciated. Thanks guys.
85 4x4 Pickup, 267K, 4d55 Conversion, Sway-A-Ways, Dual Batteries
Re: No Start [Re: dylanb] #936664 03/22/09 05:22 PM
MarkG Offline
Could it be the compression?
Re: No Start [Re: MarkG] #936665 03/23/09 04:27 AM
lordtrunks Offline
Compression test time, check the timing again if your already havn't make sure all the marks line up.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: No Start [Re: lordtrunks] #936666 03/24/09 08:06 PM
themorb Offline
This shouldn't stop it from starting, but your valve clearances should actually get smaller with a cold engine. 0.010 mm instead of 0.025 mm I think.........
When I did my engine, I could actually feel the valves get tighter as it cooled.
1991 JDM Pajero Exceed
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6021 MB (Peak: 0.6583 MB) Data Comp: Off Server Time: 2026-06-07 04:37:17 UTC
