94 isuzu trooper transmission #936798 03/22/09 02:30 AM
9
92trooper Offline OP
I need to know what year of isuzu trooper transmissions will exchange with a 1994 trooper with a 4L30E transmission thats in the truck now. Will all 4L30E transmissions work??
Re: 94 isuzu trooper transmission [Re: 92trooper] #936799 03/22/09 07:36 PM
BigSwede Offline
They are generally the same, but I would think there are wiring harness and computer control differences...perhaps JLEMOND will chime in with the info. Or try to PM him.
Does OBD II apply to trannys? Not sure. My guess is the OBD I versions will work, that would be 92-95 Troopers...but confirm that before moving on any piece.
Serenity now!
Re: 94 isuzu trooper transmission [Re: BigSwede] #936800 03/25/09 03:27 AM
JLEMOND Offline
ANY OF THE 4L30 TRANS ARE BASICALLY THE SAME UP THRU 99,AFTER THAT , THEY WONT INTERCHANGE , THE WIRING CONNECTORS AT THE TRANS WERE CHANGED AND THE TROOPERS WENT TO A PULSE WIDTH MODULATED CONVERTER APPLICATION, THAT ONLY THE TROOPER AND THE 2002 AXIOM USED , THE BIGGEST DIFF IS THAT THE LATER ONES DONT HAVE A DIPSTICK, JUST A FILL PLUG. JERRY
Re: 94 isuzu trooper transmission [Re: JLEMOND] #936801 03/26/09 04:29 AM
9
Thanks for the info I found a 98 two wheel drive that i think will work in my 94 four wheel drive. Hope to have many more questions as i take my 94 from stock to 33's and trail ready
Re: 94 isuzu trooper transmission [Re: 92trooper] #936802 03/27/09 01:17 AM
JLEMOND Offline
THE 2WD TRANS , WILL NOT WORK IN A4WD APPLICATION, BECAUSE OF THE OUTPUT SHAFT ON THE 2WD IS MUCH TOO LONG AND IT ISNT AN EASY JOB TO SWAP , JERRY OH ALLSO TROOPERS NEVER CAME WITH A 2WD TRANS UNTILL 2000 MODEL
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6051 MB (Peak: 0.6694 MB) Data Comp: Off Server Time: 2026-06-10 07:24:18 UTC
