Cleaning Turn Signal Contacts #936920 03/22/09 11:37 PM
Crops Offline OP
Read earlier that someone was experiencing buzzing from their turn signal. I had this same issue and I always thought the issue had to do with some short in the spaghetti bundle of wires that some hack did on my truck before I got it. As was pointed out in the thread, it was more likely dirty contacts within the switch itself - apparently an easy fix. So I tackled it.
Once you pop the cover housing off the steering wheel, it's a simple two screw and slide out removal!
You can see how dirty the contacts inside my switch were. I used a small cotton swatch to clean them (with some contact cleaner - or alcohol.)
Happy to report that the buzzing is gone gone gone!
89 Raider V6
95 SR Montero
Re: Cleaning Turn Signal Contacts [Re: Crops] #936921 03/23/09 12:28 AM
Bernoulli Offline
Thank you! It hasn't happened to me yet, but it's really nice to see a simple fix to a common problem.
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Re: Cleaning Turn Signal Contacts [Re: Bernoulli] #936922 03/25/09 12:37 AM
Crops Offline OP
One thing to accept when you do this is that it doesn't address every instance of failure. These switches do not have an infinite duty cycle - sometimes they just fail and you need a new one.
89 Raider V6
95 SR Montero
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5962 MB (Peak: 0.6506 MB) Data Comp: Off Server Time: 2026-06-07 07:28:03 UTC
