Gen 1 Fuel Pump Oil Leak Question
#937189
03/23/09 07:53 PM
Hello,
I think my fuel pump is leaking oil out of the breather hole. Has anyone experienced this? I have a 2.6.
Re: Gen 1 Fuel Pump Oil Leak Question
[Re: gilamontero]
#937190
03/23/09 10:59 PM
Yes.
There is a diaphragm on the fuel pump lever arm that goes to the cam. It gets torn and the oil slung off the cam leaks out the fuel pump weep hole that's there to keep a leaking pump from flooding the oil sump with fuel.
Set the motor on tdc #1 before you remove the old pump to make the lever spring relax as much as possible, or removing/installing is even more of a pain.
[Re: fasteddy]
#937191
03/24/09 12:48 AM
What fasteddy said. And on some, you may have to remove a head bolt to get the clearance for removel.
Over the hill but still climbing. 88 Montero 2.6L auto, manual hubs, cooling fan conversion gps,recurved distributor,LSD Diff.
[Re: gilamontero]
#937192
03/24/09 12:55 AM
Thanks, it has been a mysterious oil leak.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6000 MB (Peak: 0.6555 MB) Data Comp: Off Server Time: 2026-05-29 23:54:25 UTCValid HTML 5 and Valid CSS
