92 Runner Driveshaft #937351 03/25/09 03:26 AM
trcdrunner Offline OP
Hey all got a friend whose stuck...
92 4Runner 4x4 22RE 5 Speed
Driveshaft went bottoms up, UJoint let go and well he says that the end is hosed.. and is in a need of another...
What others will fit? Will a 90's V6 (runner or pup) driveshaft fit? - not sure since his is a 22re.
Will an 80's runner or pup d-shaft work?
Thanks for the info!!
PS he believes the length (from joint to joint) is 46"
aka FireNIce
84 Runner 33" Swamper LTB, 4.30's, Spool in Rear, Lock-Right soon in front exo-caged, 4" lift.
TRCD Toys Web Site
TRCD Toys Apperal
Re: 92 Runner Driveshaft [Re: trcdrunner] #937352 03/25/09 04:13 AM
Adam F Offline
He'll have to find a 90-95 or 84-89 4Runner with the same 22re/5speed combo, or possibly a shortbed standard cab pickup from the same years.
I replaced the rear shaft on my 88 4Runner with one from a 95 4Runner with the same V6/5speed combo.
Good luck finding donors in Cincy. I had a very hard time tracking one down. Most yards have newer stuff. I think I found a few older toys at Lindale Auto Parts on 132 in New Richmond. Either that or it was Duck Creek on Kellog.
Hey, contact Rob (gotbrackets here on 4x4wire, or fabricator on pirate) he has a few parts toys at his house, he might have a shaft. His email is gotbrackets AT aol.com
97 4R, stock, daily driver
Re: 92 Runner Driveshaft [Re: Adam F] #937353 03/25/09 05:51 AM
RatLabGuy Offline
I do know 5 spd and auto d-shafts are different; not by much, about 1" - but that can make a big difference.
4cyl vs 6cyl should be the same though.
Question Reality.
Re: 92 Runner Driveshaft [Re: trcdrunner] #937354 03/25/09 07:24 AM
K_Raider Offline
I believe I may have one for ya. Its an 86 22r 5-speed standard cab 4wd. Car-part says it will work. I will measure it this afternoon and let you know. Your not too far from me either.
EDIT- Went ahead and went outside to check it. The one I got extends to 48" roughly (its raining) mounting flange to mounting flange before you start seeing the splines. It was around 44" before I pulled it to 46" then to 48". I can get exact measurements this afternoon if it can help you.
88 Raider- sitting on a full size Chevy frame with 35.5x11.50x16 Dyna Torque II tractors
89 Montero- stock 2.6 M/T 30-9.50 BFG all terrains on American Racing Wheels
99 2500 Ram- 285-75-16 Uniroyal all terrains,straight pipes with no cat (yes its loud)
Re: 92 Runner Driveshaft [Re: K_Raider] #937355 03/25/09 03:27 PM
Hey thanks that may just work...
He measured center of ujoint to ujoint... so that sounds like that may just be in there...
Thanks again to all for the input!!!
aka FireNIce
TRCD Toys Web Site
TRCD Toys Apperal
Re: 92 Runner Driveshaft [Re: trcdrunner] #937356 03/25/09 04:45 PM
K_Raider Offline
Does he need one? I'll take $50 for it. Joints seem to be ok.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6096 MB (Peak: 0.6966 MB) Data Comp: Off Server Time: 2026-07-14 12:14:38 UTC
