pulling off head #937457 03/26/09 01:41 AM
kiarazy Offline OP
just curious on how hard of a project it is to pull off the head i need to heli coil one of the spark plugs, the threads stripped out. While driving down the freeway some how it loosened up and flipped upside down and the heat melted the boot from the coil and gave it room to go up and down on every stroke so it wore on the threads, hopefully it didn't do much damage to the piston the tip of the plug was preety smashed. It is not a daily driver so it can sit in the garage for a little bit. Any info would be great.
02 sportage softtop 1 inch body 4 inch suspension custom exhaust custom bumpers front and rear 31" tires
Re: pulling off head [Re: kiarazy] #937458 03/26/09 06:11 AM
bombardj1 Offline
don't need to remove the head to heli-coil, just go slow, and use lot of valsalin on the tap, then that a tube taped on a vacuum hose and stuck as much of the clippings out of the cylinder as possible if any fell off the greased tap then take a a long dowelwith a cotton tip with some vasalin and poak around the cylinder head to get anything thats left, put some sealer on the insert install it the use the seat tool and hit it with a hammer, let the sealer set up before you install the plug, use real heli-coil inserts not the cheap wire type ones.
but if it mashed the plug I don't know if it hurt the valves and or the piston, you could be opening a can of worms.
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
Re: pulling off head [Re: bombardj1] #937459 03/26/09 03:38 PM
k120189 Offline
well to pull the head the intake and exhaust manifolds have to come off.or at least the exhaust connection at the manifold and fuel/vacuum lines from the intake . the spark plugs, coils, throttle cable, valve cover,and all electrical connections. there might be a few more things...im gonna pull a junk yard head soon to port and polish im gonna get a second motor at some point as well to build a stroker. so if i get to that before u begin i'll let you know
<a href="www.pittsfieldcustomsclub.com/sportage.html" target="_blank">98 sportage</a>: warn manual hubs,upyourkia spacers, 104 tj springs, 235/75/r15 BFG T/A KO, tracker rims, cone air filter, custom cat-back with a skunk2 muffler. gonna be a 2.3L
Re: pulling off head [Re: bombardj1] #937460 03/27/09 02:01 AM
kiarazy Offline OP
if i can do it without pulling the head off would save alot of time thank you for the info and will let all know how it goes just will have to do more research on heli coiling
Re: pulling off head [Re: kiarazy] #937461 03/27/09 04:11 PM
bombardj1 Offline
http://cgi.ebay.com/Helicoil-Sav-A-...40%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
this what the kit looks like, I would not buy this one it is out of the country, hope the long link works, you need the insert length the same as the spark plug thread length. will check some other stuff out for you if I can installing a water heater today and may have to run to the store a few times.
Re: pulling off head [Re: bombardj1] #937462 03/28/09 12:59 AM
bombardj1 Offline
helicoil kit #5334-14 m14x1.25 sav-a-tread
my keypad is not working, I'm using computer in garage
I'm coping and pasting letters from anywhere off page I can get <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" />
try it <img src="/forums/images/graemlins/patriot.gif" alt="" />
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6114 MB (Peak: 0.6984 MB) Data Comp: Off Server Time: 2026-10-22 12:15:21 UTC
