Transfer case popping out of 4wd #937590 03/27/09 04:21 AM
Chip Offline OP
Greetings,
I was driving the 97 T-100 around in the snow on the roads and discovered that it is popping out of 4 hi. It doesn't forcefully pop out and it'll stay in if someone just gently holds it in place.
I drove on a dirt road in 4 hi recently and didn't have the problem but I wasn't going very fast, < 20. Now on the highway, it was frequently going out of 4wd, around every couple minutes or so.
Any thoughts on the cause and cure? Broken spring on a detent ball perhaps or something more drastic?
Thanks in advance.
Chip
Re: Transfer case popping out of 4wd [Re: Chip] #937591 03/27/09 05:14 AM
jmoser Offline
I'll guess a vacuum leak in the ADD system. Could be EZ fix with $5 - $10 of rubber tubing.
Jeff
96 T100 SR5 4WD Ext Cab, Warn Hubs, HD torsion bars, Bilsteins, Camper Shell, TJM bar, factory 31 x 10.5's, Powertrax No-slip rear, Recaro driver's bucket
Re: Transfer case popping out of 4wd [Re: jmoser] #937592 03/27/09 03:41 PM
Chip Offline OP
Would that affect the floor lever position too? Every time it popped out, the lever had moved to the 2wd position.
Re: Transfer case popping out of 4wd [Re: Chip] #937593 03/27/09 03:52 PM
CJMT100 Offline
Body lift? Ive heard that can cause it to pop out b/c the body angles hitting the shifter.
Re: Transfer case popping out of 4wd [Re: CJMT100] #937594 03/27/09 04:09 PM
Chip Offline OP
Ahhh...yes, it does have a 3" body lift, and that might explain things -- all the bouncing around on the rough roads perhaps causing the boot to pull on the lever or something. I guess a good test would be to unscrew the boot mount so the lever has nothing pulling on it.
Re: Transfer case popping out of 4wd [Re: Chip] #937595 03/28/09 03:59 AM
CJMT100 Offline
Its most likely hitting the body somewhere. You may have to cut a bit to relieve it
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6082 MB (Peak: 0.6775 MB) Data Comp: Off Server Time: 2026-07-15 02:24:53 UTC
