CEL code N/A ? Is this a dealer specific code? #937959 03/30/09 01:38 AM
homerdog Offline OP
I've got a code reader I bought at Harbor Freight and it works pretty good, however I've had a code come up and when I check the code it comes back with a code N/A. Do I need a better code reader (maybe stop at Autozone) or do I have to go the dealer and have them overcharge me to read the code?
Re: CEL code N/A ? Is this a dealer specific code? [Re: homerdog] #937960 03/30/09 02:02 AM
bombardj1 Offline
what was the code # ? or did the code reader say no code ? is the check engine light on ?
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
Re: CEL code N/A ? Is this a dealer specific code? [Re: bombardj1] #937961 03/30/09 06:03 PM
homerdog Offline OP
yes, the CEL light is and the reader says code N/A
2001 Sportage, TJ 106's, Everet spacers and bumpstops, Bilstein shocks on the rear, cone filter, Crager wheels, 235-75-15 Goodyear tires. Custom front winch bumper by Dave Scott. Currently DOA, but it is a work in progress.
2011 Kia Forte EX
Re: CEL code N/A ? Is this a dealer specific code? [Re: homerdog] #937962 03/31/09 05:54 AM
bombardj1 Offline
do you have a advance auto near you or auto zone, they will check it for you,
Re: CEL code N/A ? Is this a dealer specific code? [Re: bombardj1] #937963 04/07/09 12:21 PM
homerdog Offline OP
I took it to Autozone and it came back with a P013A code? Say's it has something to do with fuel/air metering. Any ideas?
2011 Kia Forte EX
Re: CEL code N/A ? Is this a dealer specific code? [Re: homerdog] #937964 04/07/09 12:29 PM
homerdog Offline OP
okay, I found this, where do I find a copy of the actual service bulletin?
Make : KIA Model : SPORTAGE Year : 2002
Manufacturer : KIA MOTORS AMERICA, INC.
Service Bulletin Num : 51 Date of Bulletin: JAN 01, 2002
NHTSA Item Number: 629973
Component: ELECTRICAL SYSTEM:IGNITION:MODULE
Summary:
SUBJECT REGARDING REPORTS OF DIAGNOSTIC TROUBLE CODES P013A OR P013 BEING STORED.
2011 Kia Forte EX
Re: CEL code N/A ? Is this a dealer specific code? [Re: homerdog] #937965 04/07/09 01:46 PM
bombardj1 Offline
kiatechinfo says it a short between front O2 sensor and the ecm. but they have the P013 with out the A
Re: CEL code N/A ? Is this a dealer specific code? [Re: bombardj1] #937966 04/07/09 06:21 PM
homerdog Offline OP
ok, thanks, looks like what Autozone showed me is just the generic sub-system message. I'll have to check and see if I've got a wire rubbing on something.
2011 Kia Forte EX
Re: CEL code N/A ? Is this a dealer specific code? [Re: homerdog] #937967 04/07/09 07:17 PM
bombardj1 Offline
go to www.kiatechinfo.com sign up if you have not used it before, after you put in all ifo. on your kia type in P013 it will tell you about it,
Re: CEL code N/A ? Is this a dealer specific code? [Re: bombardj1] #937968 04/07/09 08:08 PM
homerdog Offline OP
I haven't had much luck getting anywhere on that site. I can log in but that's about it, I can't ever find anything.
2011 Kia Forte EX
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6371 MB (Peak: 0.7597 MB) Data Comp: Off Server Time: 2026-07-09 16:14:12 UTC
