Page 2 of 3 1 2 3
Re: swapping engine [Re: BigJim] #938083 03/31/09 05:14 PM
Brown81CJ5 Offline
Then what I'd do is give someone else a great deal and go get me one I REALLY liked. Without spending a huge amount of time, money and effort you are pretty much stuck with what you have.
I agree. Save yourself the time and many headaches.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: swapping engine [Re: Bowfisher] #938084 03/31/09 09:30 PM
80CJ Offline
I bought this jeep last spring from an old man who used it to ride around his cattle fences and once he got done he parked it back under the garage. It has not one piece of rust and everything is in perfect condition. I just could not pass up the deal on a great buy. Now im just wanting some more power.
A friend got into a similar situation. He bought a cherry 91 YJ with 4 cylinder and 5 peeed AX5 and was disatisfied with the power. He wanted to run 31" tires. I installed 4.88 gears for him and now he can actually use 5th gear for most of his hiway driving. Our highways have a bunch of ups and downs here. If it wasn't for that 4.56 would be fine.
Re: swapping engine [Re: 80CJ] #938085 04/01/09 02:15 AM
DBL_DTY97TJ Offline
Yup, those 4 bangers do great off road with big tires and the right gears. <img src="/forums/images/graemlins/smile.gif" alt="" /> That's the easy answer.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: swapping engine [Re: DBL_DTY97TJ] #938086 04/01/09 05:08 AM
Bowfisher Offline OP
with the 4.88 gears will that take away from my low end torque. With that question asked can you explain the difference in the gear ratio {exampl: a higher gears does what and a lower gear does what.
Complete Restoration
Re: swapping engine [Re: Bowfisher] #938087 04/01/09 05:52 AM
BigJim Offline
Your Jeep prolly came with 4:11 gears.. and 26 inch tires. It should run Ok like that. If you add taller tires you will have less power as the tires are harder to turn the taller they are.
4:11 means the driveshaft turns 4.11 times to every ONE turn of the tire. so then a 4:88 gear will turn the driveshaft 4.88 times for every one turn of the tire.
So changing the gears can allow much taller tires and still keep the engine in it's power band.
Some guys with the 5 speed have put tall tires on their Jeep and cannot use 5th gear ..at all..ever.. Then they put the proper gears in their ride and it wakes up again.
You havn't mentioned the size of your tires.
Re: swapping engine [Re: BigJim] #938088 04/01/09 03:21 PM
It had a set of 235 street tires on it when i bought it and i put 31/10.5/15 MUD DAWGS on it. What would be the best ratio for that tire cause i dont plan on getting any bigger with it. And i do have the manual transmission
Re: swapping engine [Re: Bowfisher] #938089 04/01/09 04:35 PM
BigJim Offline
I flew into an abandoned WWII airfield near Greenville once in a B-25.. As I remember the terrain it is rather hilly and a beautiful place.
As is written above I'd be for the 4:88 gears. If you put them in there you will have a bunch more power. You might even start swearing by the 4 cylinder.
What the change will be..you will be able to drop the clutch from a stop without dragging it to get going.. You will be able to leave it in gear #5 on the hiway. You will also be able to "feel" more horsepower at all rpm.
Re: swapping engine [Re: BigJim] #938090 04/01/09 05:50 PM
thanks all help is greatly appreciated.I guess i gonna go get some gears and try that and see how it works. what are your thoughts on tornado air intakes and throttle body spacer kits.
Re: swapping engine [Re: Bowfisher] #938091 04/01/09 05:57 PM
Brown81CJ5 Offline
They will do you no good in a Jeep.
Gun it and run it!
Re: swapping engine [Re: Bowfisher] #938092 04/01/09 06:45 PM
BigJim Offline
Positively JUNK! Think about it.. If MOPAR could get ANY more power or fuel milage simply by changing those items they WOULD HAVE DONE IT! And prolly at LESS COST.
The tornado is a piece of CRAP and actually hinders air flow.
A SPACER under a CARB on a specially designed intake manifold can aid in filling the cylinder...but only at certain rpm which must be predetermined before installing certain thickness spacers.. putting a spacer under the TB of ANY engine can only hinder the engineered flow.
JUNK JUNK!!
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.005s) Memory: 0.6368 MB (Peak: 0.7613 MB) Data Comp: Off Server Time: 2026-10-22 00:49:55 UTC
