Rating: 1
Page 8 of 9 1 2 3 4 5 6 7 8 9
Re: 2.3L Stroker info post [Re: DEFBOY35] #938227 10/02/09 05:37 AM
SKC Offline
The front differential and the transfer case is something to worry about, though. They are both the weak points in our drive train, so I've been told.
Re: 2.3L Stroker info post [Re: SKC] #938228 10/09/09 06:30 AM
fokion Offline
coming to the stroker thing again, look this
http://carinfo.autold.com/car-kia_potentia-22.html
dont stay on the hp look at the diameter...
Re: 2.3L Stroker info post [Re: k120189] #938229 10/20/09 02:38 PM
2002_Sporty Offline
Here's what I found.
240 RWHP Stroked FE3
http://www.solomiata.com/FE3.html
2002 4dr Kia Sportage 4X4
Tires:235/75/15, Wheels: Black 15x8 Steel ProComp 2.5" B.S., Hubs:Warn Manual, Lift:3" UPYOURKIA, Trailer Hitch, Cargo Rack, Clinometer.
Re: 2.3L Stroker info post [Re: 2002_Sporty] #938230 10/20/09 02:56 PM
fokion Offline
I have read this so many times
The thing with this mod is that they were aiming for turbo-ing the engine so thei had special needs conserning straingth.
What I think we are looking for is a simple mild improuvment with aw many stock and easy to find parts that would give low torque reliably and not having to fix things every now and then
That is why the b2200 crank and rods only, if they fitted
would give a estimated 2200-2300cc with all the rest possibly stock maybe a litle bit of fuel presure more to compensate for the sligtly biger cylinders.
Why wont I try it you may ask and its pretty reasonable.
the answer is that I have a perfectly running engine and no spare money to dissasemble it just for the fun of it.
If I had a reason like worn piston rings an a smoking engine in need for a re-build, I surely would give it a try, since it would be already in pieces
Re: 2.3L Stroker info post [Re: fokion] #938231 10/23/09 04:29 AM
sportagebandit Offline
how much would it cost to do a full rebuild with the stroker parts? (i have a bad rod knock, perfect candidate) either that or engine swap... i think swapping ina junkyard motor would be the cheapest..
96 SPORTAGE 4 DOOR:1 3/8 body lift:eibach springs & spacers:15x8 rockcrawlers & 31x11.50 super swampers:warn hubs:winch bumper http://www.cardomain.com/ride/2115301
Re: 2.3L Stroker info post [Re: sportagebandit] #938232 03/18/14 07:25 PM
k120189 Offline OP
well after about 1400 years. im back been through a couple of vehicles and im picking up another sportage soon..anyone still alive here? im going to pick this back up and continue my plans to build the 2.3L stroker.
<a href="www.pittsfieldcustomsclub.com/sportage.html" target="_blank">98 sportage</a>: warn manual hubs,upyourkia spacers, 104 tj springs, 235/75/r15 BFG T/A KO, tracker rims, cone air filter, custom cat-back with a skunk2 muffler. gonna be a 2.3L
Re: 2.3L Stroker info post [Re: k120189] #938233 06/02/14 11:38 AM
4
4runnernomore Offline
Came across a guy on another Kia forum that has built a 2.3 stroker in his Sporty in Australia.
I have asked for more info <img src="/forums/images/graemlins/evil.gif" alt="" />.
Will keep you up to date <img src="/forums/images/graemlins/patriot.gif" alt="" />
Cheers, Chris <img src="/forums/images/graemlins/cheers.gif" alt="" />
97 Sporty, snorkel, K&N filter,chipped, ext forks, 40mm Dob Springs, KYB struts, 35mm Jeep TJ Springs, RAV 4 OME shocks, Kaiser Locker 5.38 R&P's, 1&3/8 body lift, 245/75 R16 D674's Sports steering wheel, bullbar, extractors & 2 1/4 exhaust engineered.
Re: 2.3L Stroker info post [Re: 4runnernomore] #938234 06/27/14 10:21 AM
Davey Offline
oooh do tell <img src="/forums/images/graemlins/smile.gif" alt="" />
Long a$$ 2000 Sporty, auto, 5.38 gears, TF front locker, 4"+ front lift (Kings +40 springs, 50mm spacers, 1.5" diff drop), TJ 104 rears 3" + 50mm coil spacers, 1.5" body lift, 31/10.5r15's on 15x8 Kings (ET-13), WARN manuals, Smart Bar, spotties
Re: 2.3L Stroker info post [Re: Davey] #938235 06/27/14 11:51 PM
4
Hi Davey,
You might know the car or person? It is a red sporty in WA. Goes by DPK on the Kia forum. Have sent him a couple of PM's
. No reply yet.
Cheers Chris <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 2.3L Stroker info post [Re: 4runnernomore] #938236 07/08/14 01:11 AM
4
Hi all,
I am still waiting on a detailed reply from Dave (DPK) from the Kia forum however I did get a snippet from him about his 2.3 stroker motor which includes briefly R2 crank diesel , std rods ;manufactured pistons.
Once I find out more I will post up for all to see <img src="/forums/images/graemlins/patriot.gif" alt="" />
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.006s) Memory: 0.6438 MB (Peak: 0.7675 MB) Data Comp: Off Server Time: 2026-10-21 19:37:39 UTC
