Cool engine swap
#938246
03/31/09 06:59 PM
I was in a shop the other day and saw what looks to be a good swap in progress. It was a 318 V8 out of a GC going into a TJ. The wiring harness was almost a perfect match. There were only two (maybe 3) connections that needed modification. The TJ just needed a 1" BL to get all the components to line up right on.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD.
Re: Cool engine swap
[Re: DBL_DTY97TJ]
#938247
03/31/09 07:09 PM
How did it look in thee? Is there plenty of room to work around? Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#938248
04/01/09 12:06 AM
What year Grand and what liter?
01' TJ Wangler, 6" Ruff Country X Series, 35" x 12.5" Mickey Thompsons On 15 x 10" rims w/ simi Bead Lock, Matching Warn Bumpers, 9500xi Warn Wench, Tom Woods Drive Shaft And SYE, And A K+N Cool Air Intake. Still Improving
[Re: BigJim]
#938249
04/01/09 02:04 AM
It didn't take up any more room than the I6. Same radiaor, shroud, everything. I forgot to ask what year the vehicles were. It looked like DC could have made it a nearly no cost option though. It was that simple a switch. I can find out more about it if you want.
[Re: DBL_DTY97TJ]
#938250
04/01/09 02:15 AM
Just wondering if it could be the 4.7 V8. I love the 4.7 in my 01 GC Larado. Much power and torc, would probably do great in a Wrangler with the weight diff.
[Re: reepersteve]
#938251
04/01/09 07:08 AM
Just wondering if it could be the 4.7 V8. I love the 4.7 in my 01 GC Larado. Much power and torc, would probably do great in a Wrangler with the weight diff. A 318 c.i. engine is bigger than 4.7 liters -- probably around 5.2 to 5.3 liters.
[Re: BobRowe]
#938252
04/01/09 12:18 PM
Thanks for info, I did not know that.
