Page 2 of 4 1 2 3 4
Re: Tube Fender DIY Project [Re: 2000Trooper] #938266 04/09/09 01:27 AM
DBL_DTY97TJ Offline
Been enjoying your write-up. How much difference does the gas make to your welding? My little 110v mig has gas capability, but I've never used it and I'm such an amature welder I don't think it would help me much. Just wondering. I can do reasonably well w/material less than 1/8" thick (getting at it from one side), but it's not pretty. Like to hear your take....
Thanks,
- Chris
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: Tube Fender DIY Project [Re: DBL_DTY97TJ] #938267 04/09/09 01:39 PM
2000Trooper Offline OP
For the thinner materials it really makes a big difference. I also like that I don't have to cleanup as much (minimal splatter). I am using the 75/25 (argon/co2) gas mix.
For the thicker material I still use the flux-core wire. I have a Lincoln SP140 110 unit that works really well.
Jaime
Re: Tube Fender DIY Project [Re: 2000Trooper] #938268 04/10/09 02:18 AM
DBL_DTY97TJ Offline
I'll have to give the gas a try. I've got the Lincoln Pro-Core 100. Looks pretty much the same as the Sp 140. I've seen small tanks in Lowe's for pretty cheap (might have been just CO2), might start with that. Kewl! Thanks,
- C <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Tube Fender DIY Project [Re: DBL_DTY97TJ] #938269 04/10/09 04:36 PM
It should be an improvement even with strait co2. I tried it with co2 but the spatter was still noticeable. Of course this was with a ReadyWelder II that attached to batteries. I just could never dial it in to weld properly. It might of been the ReadyWelder that was the problem though.
Let us know how strait co2 does for you.
Update:
I finally got started on the passenger side fender. This one should go a lot smoother from the lessons learned from doing the driver side.
I drilled the rear and front brackets and welded the top and bottom tubes in place. I also welded the top plate to the tubes. This plate required some modifications due to the fuse box and the battery.
I am off to Dallas to visit the King Tut exhibit on Saturday. Will continue working on the fender next week.
I will post some pictures later on today (forgot my memory card at home).
Jaime
Re: Tube Fender DIY Project [Re: 2000Trooper] #938270 04/11/09 03:13 AM
Oyaji_Jon Offline
You're rockin' on that thing. Keep the info coming! I'm watching this closely...
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Tube Fender DIY Project [Re: Oyaji_Jon] #938271 04/13/09 03:45 AM
Thanks,
Some pictures of the passenger build:
Front and rear brackets:
Top bar installed:
All tacked together:
Jaime
Re: Tube Fender DIY Project [Re: 2000Trooper] #938272 04/13/09 02:19 PM
Got these on Friday:
Jaime
Re: Tube Fender DIY Project [Re: 2000Trooper] #938273 04/14/09 02:25 AM
DBL_DTY97TJ Offline
Hey,
Some pics of the King Tut exhibit would be really cool too...Not like I'll be able to get there. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Tube Fender DIY Project [Re: DBL_DTY97TJ] #938274 04/14/09 02:04 PM
Brown81CJ5 Offline
How long is that exhibit in dallas? Sounds pretty interesting. Though I could have sworn I've seen it here already before.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: Tube Fender DIY Project [Re: Brown81CJ5] #938275 04/14/09 02:32 PM
Hey,
You know the bad thing is that they did not allow photos to be taken once inside the exhibit. So no pictures of the actual artifacts. The great thing is that some of the items that we see in those black and white original photos of when they found the tomb, are in the exhibit.
It's running from October 3, 2008 to MAY 2009.
Jaime
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6411 MB (Peak: 0.7660 MB) Data Comp: Off Server Time: 2026-10-24 03:17:17 UTC
