Help!! Blown head gasket or cracked head?
#938619
04/03/09 06:07 AM
Is there any way to tell the difference between a blown head gasket and a cracked head before tearing into it?
It sputters violently and blows out thick white exhaust for a few minutes before smoothing out and it's always low on coolant after driving a little while.
Any suggestions?
'86 4runner ARB bull bar, Warn 8000, daily driver
Re: Help!! Blown head gasket or cracked head?
[Re: Nato99]
#938620
04/03/09 07:03 AM
Not really; either way you'll be tearing into it to replace the gasket and get the head remilled and pressure checked anyway. The non-invasive stuff first:
Oil cap- oily milkshake? You would also see something with the valve cover off. Compression check- 2 low number adjacent to each other generally points to a head gasket. Plugs- white indicates the presence of coolant, as does your white smoke and coolant consumption.
Your other little gremlin might be a timing chain cover that ate a hole thru the cover and into the water pump. Got a rattle on startup?
[Re: kewlynx]
#938621
04/03/09 07:22 AM
Thanks Kewlynx
Good thinking on the compression check, that hadn't crossed my mind. The oil is clear and i haven't noticed any unusual clattering on start up but I'll have to make sure and check on the next start up.
[Re: Nato99]
#938622
04/03/09 07:27 AM
Kewlynx Can you expound on that last point? How would the timing cover wear a hole in the water pump and how would that produce thick, white exhaust?
[Re: Nato99]
#938623
04/03/09 07:31 AM
Sorry the chain wears a hole if it breaks the guides and starts slapping around. Eventually it'll wear a hole thru the TC cover and over into the water passage for the pump. http://www.4x4wire.com/toyota/maintenance/timingchain/White exhaust = coolant. Blue exhaust = oil.
[Re: kewlynx]
#938624
04/03/09 07:42 AM
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6110 MB (Peak: 0.6807 MB) Data Comp: Off Server Time: 2026-05-29 20:01:46 UTCValid HTML 5 and Valid CSS
