runner won't start UPDATE #938812 04/04/09 11:20 PM
TexJeff87 Offline OP
Folks,
Been a while since I've posted.
I was driving the 4 runner around the place today, pulling stumps. Took a break for lunch, came back, tried to start it...it stumbled once. The engine is turning, but no start. I left the key on and cracked the fuel line banjo bolt on the intake manifold...no gas. I put 2.5 gallons in, still no gas coming out at the bolt. I put a voltage meter on the power plug for the fuel pump...no current. Shouldn't I be seeing 12 volts there with the key on?
Here's a recent pic...
[img][image]http://i5.photobucket.com/albums/y198/TexJeff87/DSCF0041.jpg[/img][/image]
If Mad Max had a 4runner...
Re: runner won't start [Re: TexJeff87] #938813 04/05/09 12:50 AM
4Crawler Offline
Only have power to the pump if the Air FLow Meter flap is open, or you install the fuel pump test jumper:
- http://www.4crawler.com/4x4/CheapTricks/index.shtml#FuelPump
Re: runner won't start UPDATE [Re: TexJeff87] #938814 04/06/09 12:55 AM
OK, did the diag jumper. There is power going to the fuel pump, I checked it at the pump connector. I cracked the banjo bolt on the manifold open and turned on the key ( with the jumper still in place ) and no fuel.<img src="/forums/images/graemlins/confused.gif" alt="" /> That sounds like a sick fuel pump. What do you think?
Re: runner won't start UPDATE [Re: TexJeff87] #938815 04/06/09 01:10 AM
Adam F Offline
Sounds like your right.
Last thing you can do is run a jumper from the battery directly to the fuel pump and see if it comes on. Then you'll know for sure.
Luckily theres a panel under the rear seat to access the pump. Just be careful removing the bolts, they break off easy.
97 4R, stock, daily driver
Re: runner won't start UPDATE [Re: Adam F] #938816 04/06/09 01:21 AM
That's gotta be it. I even cracked the line pre-filter and turned on the key...go gas...
Re: runner won't start UPDATE [Re: TexJeff87] #938817 04/06/09 01:30 AM
kewlynx Offline
One in the FS section....
**ubi apis- ibi salus**
Re: runner won't start UPDATE [Re: kewlynx] #938818 04/06/09 03:19 AM
G
Greg_Canada Offline
URD sells walboro fuel pumps for 90 bucks bolt in.
89 4Runner
Re: runner won't start UPDATE [Re: Greg_Canada] #938819 04/08/09 12:20 AM
If I'm on the right site (URDUSA.COM ) they don't have one for a 22RE.
Re: runner won't start UPDATE [Re: TexJeff87] #938820 04/08/09 02:49 PM
G
Greg_Canada Offline
Fuel pumps really havent changed. the 2/3rz one should work. im going to get the 5vz one fro my 3vz.
89 4Runner
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6302 MB (Peak: 0.7330 MB) Data Comp: Off Server Time: 2026-06-07 04:38:12 UTC
