99 rodeo frozen compressor #938996 04/06/09 01:00 AM
TexJeff87 Offline OP
The AC compressor on my 99 rodeo is frozen. Do I have to pull it off to put on a non-AC truck belt?
thanks
If Mad Max had a 4runner...
Re: 99 rodeo frozen compressor [Re: TexJeff87] #938997 04/07/09 02:29 AM
mlclark Offline
Isuzu Moderator
Compressor or pulley?
If it is the pulley, take a look at the pulley diagram (should be under the hood, or on the core support) and see if you can bypass it with the non-AC belt.
If it is the compressor, unplug the clutch and call it good.
Good Luck,
Michael
Re: 99 rodeo frozen compressor [Re: TexJeff87] #938998 04/09/09 11:48 PM
JLEMOND Offline
thanks
NOT 100% SURE IF THE BELT WILL CLEAR THE COMP TOP EDGE , WITH THE SHORT BELT ,FOLLOW MICHAELS DIRECTIONS ON THE BELT , IF YOU NEED THE SHORT BELT IT IS AVAILABLE FACTORY SIZED , FACTORY PT NO IS 897 130-5610,ANY AUTO PARTS STORE CAN CROSS REFERENCE BUT I WOULD RECOMMEND THE HI GRADE DAYCO BELT, JERRY
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.5925 MB (Peak: 0.6457 MB) Data Comp: Off Server Time: 2026-06-23 11:14:44 UTC
