SAS Trooper using Scout II donor (maybe) #939125 04/06/09 04:43 PM
P
pete3 Offline OP
Does anyone have any words of wisdom on a SAS using a '77 Scout II front axle? May have the chance to get the front axle for nothing and wondering if it would be worth putting under my '89 Trooper. It does have disc brakes but has a 5 lug wheel vs. the 6 of the Trooper. Can that be converted?
pete
1989 trooper-3" susp. lift, h.d. indy4x tie rods, aisins, tera lows, aussie locker(front)/lincoln locker(rear), 33" mud grapplers on black rock crawlers, homemade bumpers and sliders, hella 500's, surco roof rack, paint & body by busch light
Re: SAS Trooper using Scout II donor (maybe) [Re: pete3] #939126 04/06/09 05:05 PM
mlclark Offline
Isuzu Moderator
Can it be converted? Of course, enough money can convert anything. Just ask Curtis and his locking hub conversion on the rear of his Rodeo. Of course, he also paid with a good bit of headache too.
The questions is: Do you want to (or can you) mess with it?
The preferred D44 axle is fom the Wagoneer. Someone here will be able to give you some ideas about the binder axle, but...I would ask, why make it harder than need be.
And:
http://www.4x4wire.com/forums/showf...&Number=647703&Forum=c15
Read. Lots of good info.
Michael
Re: SAS Trooper using Scout II donor (maybe) [Re: mlclark] #939127 04/07/09 12:57 PM
RobG Offline
consider the cost of a junkyard waggy D44 is typically between $100-$200 without too much trouble. you may spend that on coverting the axle even if you got it for free.
-Rob
Re: SAS Trooper using Scout II donor (maybe) [Re: RobG] #939128 04/07/09 09:25 PM
P
pete3 Offline OP
Is the bolt pattern on the Wagonneer 44 the same as the Trooper (or Toyota) so i could run my same wheels? What about the width?
pete
Re: SAS Trooper using Scout II donor (maybe) [Re: pete3] #939129 04/08/09 02:23 AM
mlclark Offline
Isuzu Moderator
Ahem...
Read
If you are really set on doing this, you've got to do your homework. There are a lot of folks who have gone before you, luckily they sometimes bless us with their presence.
Michael
Re: SAS Trooper using Scout II donor (maybe) [Re: pete3] #939130 04/08/09 01:14 PM
RobG Offline
yes, old jeeps and chevys use the same 6-lug pattern as isuzu and toyota. and based on you asking that question, I would take some time to do some heavy research before picking up any parts for an SAS, free or otherwise.
-Rob
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6115 MB (Peak: 0.6822 MB) Data Comp: Off Server Time: 2026-05-29 22:32:29 UTC
