Page 1 of 3 1 2 3
wheel backspacing on 2" lift #939396 04/08/09 04:51 PM
3
357transam Offline OP
Hey guys, sorry for the repeat, but i couldnt seem to find where i had seen it before. I am trying to figure out what the minimum backspacing for wheels i need. I have a set of 31x10.50s, and a 2 inch lift. could you point me towards what thread i need?
Re: wheel backspacing on 2" lift [Re: 357transam] #939397 04/08/09 06:53 PM
k120189 Offline
i would pint u to the thread about more lift.. they might clear the back but i doubt they will clear in the front.
<a href="www.pittsfieldcustomsclub.com/sportage.html" target="_blank">98 sportage</a>: warn manual hubs,upyourkia spacers, 104 tj springs, 235/75/r15 BFG T/A KO, tracker rims, cone air filter, custom cat-back with a skunk2 muffler. gonna be a 2.3L
Re: wheel backspacing on 2" lift [Re: k120189] #939398 04/08/09 10:03 PM
3
well, i am fully expecting to use a 20 pound sledge and maybe a sawzall, but is 4.5" backspacing about normal to run? i know i ran across a thread that said the backspacing of the stock wheels, but i cant find it.
Re: wheel backspacing on 2" lift [Re: 357transam] #939399 04/08/09 10:39 PM
3
well, i just went and measured the backspacing of my stocker, and its 5.5".
Re: wheel backspacing on 2" lift [Re: 357transam] #939400 04/09/09 01:31 AM
DennisThompson Offline
You want to stay as close to the stock backspacing as posible, especialy with only 2 inches of lift. I had to cut the corner of my bumper and pound on the back of the fender and inerfender to get 31s to fit with a 4" lift and 4" of backspacing. You also want to at least 7" wide wheels, the stock 6" wide wheels could cause pour, squerly handling.
Dennis
Re: wheel backspacing on 2" lift [Re: DennisThompson] #939401 04/09/09 01:46 PM
3
all right, i guess i will need to look into something different than i was looking at... thanks for the info!
Re: wheel backspacing on 2" lift [Re: 357transam] #939402 04/09/09 03:43 PM
k120189 Offline
well im running 31's on tracker rims which might actualy have alittle less backspacing maybe..and everet's spacers and i only rub alittle. then again i only have about an hours driving with the lift in finished at 2am...
Re: wheel backspacing on 2" lift [Re: k120189] #939403 04/09/09 08:06 PM
3
are you only running the 2" setup?
Re: wheel backspacing on 2" lift [Re: 357transam] #939404 04/10/09 12:57 AM
jaboo5322 Offline
I have 4" lift, 8" rim, 31x10.5 tire, and I had to cut underside of front bumper, and rear of fender well. Still while turning and hitting a bump offroad, it rubs allitle. And i have a chance to buy 35x12.5 tsl thornbirds, brand new, for about 250.00 dollars. Imagine the cutting for that. <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> Poor, poor, Kia. <img src="/forums/images/graemlins/nana.gif" alt="" />
2001 Sportage, 4" RSG lift, Cragers W/31 10.5 Micky Claws, Warn Manual Hubs, 16 gallon Pro Street Fuel Cell, Custom Snorkel, K&N Filter.
1989 Dodge W250.
Re: wheel backspacing on 2" lift [Re: jaboo5322] #939405 04/10/09 04:46 AM
DamKia Offline
Kia Moderator
Wouldn't even go there unless you're doing a SAS. Biggest and most immovable issue is the chassis end of the bodymount near the firewall. Under compression when 3/4 lock you WILL hit this and no amount of bodylift, springlift or wheel backspacing can change the chassis. 32" measured (not optimistic manufacturers "measurements") will max out this clearance.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.008s) Memory: 0.6364 MB (Peak: 0.7596 MB) Data Comp: Off Server Time: 2026-07-16 08:52:03 UTC
