Are IFS Front Differential Assemblies The Same, '86 -'88 and '89 - '95? #940119 04/13/09 06:38 PM
matts Offline OP
As I'm dismantling my other '89 4runner (not my good '89 4runner <img src="/forums/images/graemlins/notooth.gif" alt="" />) I'm wondering if the front axle/differential assemblies are interchangeable across the years '86 - '95 and between 4 cyl and 6 cyl applications. I know there were some with auto-disconnect differential. Are there any other differences?
I'd like to rebuild the front axle assembly from my 4cyl '89 4runner parts truck and install 4.88 gears in it for my '93 V6 pickup. -- Matt
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
Re: Are IFS Front Differential Assemblies The Same, '86 -'88 and '89 - '95? [Re: matts] #940120 04/14/09 03:37 AM
OOP'S Offline
Yep!!!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Are IFS Front Differential Assemblies The Same, '86 -'88 and '89 - '95? [Re: matts] #940121 04/14/09 03:25 PM
RatLabGuy Offline
yep, all the same, as far as interchangability.
Later ones have the ADD system, as you mention - but you can put an ADD front diff on a non-ADD truck no problem, just permanently "fix" teh sliding rod in there and plug the vac lines.
but axles, gears, everything else is identical.
Question Reality.
Re: Are IFS Front Differential Assemblies The Same, '86 -'88 and '89 - '95? [Re: matts] #940122 04/19/09 08:16 PM
ZUK Offline
Just remember....if you ever have do any "re-bearing work" that you have to know if your IFS carrier is out of a 4 cyl or a V6 model (V6 has larger 50mm carrier bearings)....and that's about the only notable difference. ZUK
mostly stock
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6046 MB (Peak: 0.6603 MB) Data Comp: Off Server Time: 2026-06-07 09:08:42 UTC
