change motor #940130 04/13/09 09:09 PM
L
lawrence42 Offline OP
i have a isuzu 2.6 i want to put a chev 2.8 do i have to have everything i can get a s10 rollover when i change do i use everything including the comp
Re: change motor [Re: lawrence42] #940131 04/14/09 12:50 AM
strawmyers Offline
Isuzu Moderator
You will have to get everything INCLUDING the transmission since the 2.6 and 2.8 do not share bolt patterns. Why take the time/effort for that engine swap <img src="/forums/images/graemlins/confused.gif" alt="" /> The 2.8 isn't much more motor than the 2.6 power-wise. IMHO, an engine that is more of an upgrade would be a better choice.
Sean Strawmyer
Re: change motor [Re: strawmyers] #940132 04/14/09 03:42 PM
L
what motor would be best i hate this 2.6 i want to get rid of it
Re: change motor [Re: lawrence42] #940133 04/14/09 04:25 PM
K_Raider Offline
The 2.8 is a dog. If you swap that in, you will regret it. I had one in my S10 Blazer. Go with the 4.3 Chevy from a late 80's early 90's S10 or S10 Blazer.
88 Raider- sitting on a full size Chevy frame with 35.5x11.50x16 Dyna Torque II tractors
89 Montero- stock 2.6 M/T 30-9.50 BFG all terrains on American Racing Wheels
99 2500 Ram- 285-75-16 Uniroyal all terrains,straight pipes with no cat (yes its loud)
Re: change motor [Re: lawrence42] #940134 04/14/09 08:44 PM
jezeric Offline
Isuzu Moderator
What is it you're unhappy with in the 2.6, and what do you want to do with your truck when it's all done? That may have some impact on what recommendations you get on options.
Re: change motor [Re: jezeric] #940135 04/15/09 12:29 AM
Jim_Paget Offline
I think that the first thing that I would do is run a compression test on the 2.6. If the prior owners haven't been meticulous about doing the valve adjustments, there is a pretty good chance that you have one or more burned valves.
Before replacing the engine I would make sure that the 2.6 is performing as it should.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: change motor to from 2.6 to 2.8. [Re: strawmyers] #940136 04/18/09 09:14 PM
republic Offline
IF a guy were to swap a 2.8 for the 2.6, T-5 transmission and all, would the clutch fork be a problem? What about the speedometer gear/cable? This may not be the best choice but the 2.8 is practical and available. I appreciate your replies.
Re: change motor to from 2.6 to 2.8. [Re: republic] #940137 04/19/09 12:43 AM
Jim_Paget Offline
The Isuzus use two variations on the MUA transmissions behind the 2.6 and the 2.8. Both use a hydraulic clutch.
On the 2.6, the slave cylinder is on the right (passenger) side of the tranny and on the 2.8, the slave is on the left (driver) side.
To the best of my knowledge, Isuzu never used the T-5 behind either (I am sitting here with the FSM and it only lists the MUA transmission).
In addition, the tranfer case is integral with the MUA, whether in the 2.6 or the 2.8. Assuming that you want to keep the 4X4 capability, you are probably in trouble using the tranny out of an S-10, as I believe that the S-10 uses a driver's side drop for the front drive shaft, while all the Isuzus use a passenger side drop.
Even if you want to go to 2X4, you are going to have to fabricate something for a transmission cross member.
Jim Paget
www.rrr4x4.com
Re: change motor to from 2.6 to 2.8. [Re: Jim_Paget] #940138 04/19/09 02:04 AM
republic Offline
Jim, thanks for the reply. I neglected to mention the Rodeo is 4X2, so the transfer case is not an issue. It sounds like finding an MUA would be the smoothest swap Thanks again, Phil
Re: change motor to from 2.6 to 2.8. [Re: republic] #940139 04/19/09 04:07 AM
republic Offline
Jim, just following up. I'm looking at the 1991 Rodeo owner's manual. It says that indeed Isuzu used the BW-T5.
According to page 8-16, the BW-T5 is used only on 2-wheel drive V6 models. All other manual transmission models are equipped with MUA type transmissions.
Phil
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6349 MB (Peak: 0.7590 MB) Data Comp: Off Server Time: 2026-07-15 13:20:02 UTC
