Source needed for Transmission Parts #940204 04/13/09 10:23 PM
87_Montero Offline OP
Stacey, my transmission repair guy, says he can't find any parts for the Gen I V-6 manual transmission.
Stacey says he needs 4 main bearings, synchronizer rings, and a couple of shift forks.
Does anyone know of a source for these parts?
Thanks,
Bob
Monty
DDs:
Projects: 86 Ram50
Re: Source needed for Transmission Parts [Re: 87_Montero] #940205 04/14/09 04:16 AM
On the right...
<img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: Source needed for Transmission Parts [Re: rxinhed] #940206 04/14/09 03:14 PM
Russell,
Would you have useable transmission components in one of your parts cars?
I guess I've been under a false impression, that the internal components in a well used transmission will be experiencing wear, even though symptoms of failure haven't started yet.
Would you seek to ship me an entire transmission, or send me components?
Maybe my best route would be to just swap out the current tranny for another one.
Thanks,
Bob
DDs:
Projects: 86 Ram50
Re: Source needed for Transmission Parts [Re: 87_Montero] #940207 04/14/09 04:07 PM
Re: Source needed for Transmission Parts [Re: OldColt] #940208 04/15/09 03:56 AM
Bob,
I was just pointing out that transmission parts are available, even if you pick up a whole car to get what you need. The aqua Montero has a stick, but 225K + miles onboard.
Russell
Re: Source needed for Transmission Parts [Re: OldColt] #940209 04/16/09 03:15 PM
Thanks!
I'll see whether they can help.
Bob
DDs:
Projects: 86 Ram50
Re: Source needed for Transmission Parts [Re: 87_Montero] #940210 04/19/09 11:00 PM
Mudrunner, you get desperate, I can check into one @ a out-of-the-way yard I found. PM me if you want and I'll check with them.
Re: Source needed for Transmission Parts [Re: 87_Montero] #940211 04/20/09 04:54 AM
KrzyDav Offline
Rock Auto list parts for the 4 banger. They list parts for the V6 but they are for the 2.6 .
dave h.
Re: Source needed for Transmission Parts [Re: KrzyDav] #940212 04/21/09 08:35 PM
raiderquest Offline
Try George at A1 Trans Parts, Denver, Colo.
(303)623-1401
Re: Source needed for Transmission Parts [Re: OldColt] #940213 05/12/09 10:38 PM
Thanks for the source.
Drivetrain.com had this info for me:
3.0 liter V6 5speed, 1989-1997, Transmission V5MT1
Drivetrain Kit ID K100346
Synchronizer Kit $161.36
Bearing Kit $146.36
Forks not in stock but possibly available in warehouse
DDs:
Projects: 86 Ram50
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6387 MB (Peak: 0.7619 MB) Data Comp: Off Server Time: 2026-06-17 06:36:19 UTC
