Stink smell? #940331 04/15/09 01:57 AM
Macneal Offline OP
Hey I been having this stinky rotten egg smell coming from my Kia after driving it for a while. Not sure what it could be coming from. Think its the A/C or Heater core? Any one have this problem to? is there a way to fix it? I got a strong stomach but when stopped at a light i can smell it with the windows down and sometimes even through the vents.
Re: Hello. [Re: Macneal] #940332 04/15/09 04:18 AM
ChrisB Offline
Welcome to the site <img src="/forums/images/graemlins/cheers.gif" alt="" /> The sportage makes a very capable rig.Mine is stock just removed the front bumper and added warn manual hubs and it has been places my brothers lifted jeep has had probs
01 Kia sportage,Removed front bumper,Warn manual hubs,
Soon To Come.Cb,4"lift,31's,Custom front bumper,Rock sliders,Winch,Roof rack,Hitch
Make it Break it
Re: Hello. [Re: Macneal] #940333 04/15/09 06:47 AM
6
69442 Offline
Welcome <img src="/forums/images/graemlins/cheers.gif" alt="" />
LIFT OR BUST! 2001 Sportage EX 4dr 4WD with 300,210 miles & counting .....
____o_o
l_l_l\___\___
l----[o]==[o]
l----==[--]==
()_)()_)--()_)
Re: Hello. [Re: Macneal] #940334 04/16/09 12:55 AM
DennisThompson Offline
Welcome, you have just joined the best Kia forum on the web. There are some very knowledgeable people here. You will find that your Kia will shock alot of wheelers on the places it will go. With a mild lift and longer rear shocks they have a lot of rear wheel travel, just make sure you don't go so long your springs fall out. Also make sure you protect your oil pan, they are kind of in harms way.
Have fun, Dennis
Re: Hello. [Re: DennisThompson] #940335 04/17/09 06:55 PM
k120189 Offline
you would have had more luck it you posted anew post...
is the kia acting sluggish as well? could be the cat
<a href="www.pittsfieldcustomsclub.com/sportage.html" target="_blank">98 sportage</a>: warn manual hubs,upyourkia spacers, 104 tj springs, 235/75/r15 BFG T/A KO, tracker rims, cone air filter, custom cat-back with a skunk2 muffler. gonna be a 2.3L
Re: Hello. [Re: k120189] #940336 04/18/09 02:48 AM
ChrisB Offline
Do our ECU's use capacitors on the board?I had an eclipse that smelt like roting eggs.Turned out the capacitors in the ecu went bad an leaked.
Make it Break it
Re: Stink smell? [Re: Macneal] #940337 04/18/09 04:24 AM
londart Offline
i would guess the catalytic converter, wont always act sluggish either..if its coming thru ur vents its probably coming from outside of ur car...never heard of a heater or air conditioning part smelling like rotten eggs, usually that would be more like dirty socks...a bad battery or overcharging battery can also give that sulfur (rotten egg) smell <img src="/forums/images/graemlins/cheers.gif" alt="" />
Lonnie
Auto Parts Professional
95 sportage sold but not forgotten
Re: Stink smell? [Re: londart] #940338 04/18/09 04:03 PM
What happened to this thread, it started out as a new member that bought his wife a sporty and turned into rotten eggs? Some how they got mixed up and the original post is gone.
If the rotten egg smell is coming for outside and working is't way in as you come to a stop it is most likely the catalytic converter, if it is originating inside I'm stumped.
Dennis
Re: Stink smell? [Re: DennisThompson] #940339 04/18/09 04:59 PM
Macneal Offline OP
Sorry for not starting a new post. Not sure how to delete This current one <img src="/forums/images/graemlins/confused.gif" alt="" /> Or will it automaticly just delete it self upon my nexted post? And I gonna try and remove the cat. Witch one should I check the one right after the exhaust manafold or the one after that? Thanks for the info on the Stink smell.
Re: Stink smell? [Re: Macneal] #940340 04/18/09 05:36 PM
londart Offline
not sure which cat to check, it could be either...u dont delete ur posts though they just move down the list as others post new ones and will move back to the top as comments are posted on ur original post, just start a new 1 if its on a different subject
Lonnie
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6311 MB (Peak: 0.7385 MB) Data Comp: Off Server Time: 2026-06-17 01:38:32 UTC
