question about cylinder heads on 89 mitsu.
#940518
04/15/09 03:13 PM
I don't recall who told me this, but I know i heard it. Is the Cylinder head on the 89 different than the other 4cyl? I thought someone said the Jet valves were different? I don't know if this was for 84-89 or just something different on 89 only. Can anyone tell me if this is true? Thanks.
89 Montero, 2.6L 4cylinder. G54B
Re: question about cylinder heads on 89 mitsu.
[Re: Thor]
#940519
04/15/09 09:37 PM
AFAIK, all the late 2.6 heads are the same.
[Re: fasteddy]
#940520
04/16/09 06:04 AM
Thanks. I found a extra one and wasn't sure. talked to a guy about hydraulic and he said he recommended the hydraulic though he had mechanical too. stated the latter was better, had extra cooling holes with a better thick alloy in the right places. Was curious because Had heard they were different. thanks again.
[Re: Thor]
#940521
04/16/09 11:21 AM
The 89 turbo head is different, I never thought if this would also be true in a normally aspirated application. Visually the 89 Turbo head has massive exhaust guide extension down into the port. This could be in an 88 head also. I did not research for any other differences.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6045 MB (Peak: 0.6599 MB) Data Comp: Off Server Time: 2026-11-02 04:03:13 UTCValid HTML 5 and Valid CSS
