Page 1 of 3 1 2 3
No start on a 3.5L DOHC 95SR - Inhibitor switch? #940636 04/16/09 01:18 AM
nedfunnell Offline OP
My 95SR won't start or turn over. Good battery voltage which doesn't sag much when I try to start. No click either. The starter isn't spinning at all. I have been having trouble with the park/neutral position switch, and I suspect the safety feature which prevents starting in gear is inhibiting the starter. The park/neutral is currently attached to the vehicle, but not adjusted correctly, so that the computer doesn't actually know what gear it is in. However, I have tried messing around with it temporarily so that that "P" light is on when the transmission is in Park, and it still won't start. It's just a simulation of the properly adjusted switch, but I thought it would work. If it's not this, any ideas what else it could be?
Also, I am changing jobs in a few weeks and would be open to selling this vehicle. I am in Iowa. Any offers?
95 Montero SR - 207k miles, rebuilt @ 146k
Stock. Longview, Texas
Ithaca, NY for the summer of 08.
Re: No start on a 3.5L DOHC 95SR - Inhibitor switch? [Re: nedfunnell] #940637 04/16/09 02:02 AM
V
vr4 Offline
its either the ignition switch, inhibitor switch, or the starter.
im sure theres a fuse or 2 that could be bad also.
sorry i cant help you (never had to deal with this) but break outt he test light and start checking things over.
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Re: No start on a 3.5L DOHC 95SR - Inhibitor switch? [Re: vr4] #940638 04/16/09 02:52 AM
justice Offline
On both my 95 SR's the ignition switch wore out. Not to say that's your problem, but it is common. The part that houses the electrical contacts is plastic and unscrews from the back of the tumbler. Not too expensive IIRC. I was able to clean mine by dissasebling it but it only bought a month or so time and I replaced it with a new part.
Re: No start on a 3.5L DOHC 95SR - Inhibitor switch? [Re: justice] #940639 04/22/09 02:11 AM
I cleaned up the ignition switch and didn't get any result. Where is the inhibitor? I tore the center console apart after reading a thread of someone fixing their Raider that way, but I didn't find it in the console. I haven't looked at the starter yet- the FSM says you have to drain the transmission and remove the dipstick tube to get it off. Is that right?
Thanks for your help.
Re: No start on a 3.5L DOHC 95SR - Inhibitor switch? [Re: nedfunnell] #940640 04/22/09 05:21 PM
V
vr4 Offline
most likely. theyre usually bolted to the trans at the shifter cable/rod.
91 MR2 turbo
Re: No start on a 3.5L DOHC 95SR - Inhibitor switch? [Re: vr4] #940641 04/22/09 06:58 PM
It's in the selector detector switch on the dside of the tranny.
Re: No start on a 3.5L DOHC 95SR - Inhibitor switch? [Re: fasteddy] #940642 04/23/09 12:45 AM
Do you mean the park/neutral position switch? I've been messing with that, but it's on the passenger side.
Re: No start on a 3.5L DOHC 95SR - Inhibitor switch? [Re: nedfunnell] #940643 04/24/09 02:27 AM
Well, I know it's not the starter or the solenoid. I was able to jump it with the key in 'on' and a wire across the battery lug and S connection on the solenoid.
http://www.youtube.com/watch?v=vi7JmYgqiG8
See?
Who wants it?
Re: No start on a 3.5L DOHC 95SR - Inhibitor switch? [Re: nedfunnell] #940644 04/24/09 04:26 AM
Check the continuity or voltage drop across the ignition switch. You should be able to take the electrical part of the ign sw. off the lock part with a couple of screws.
Re: No start on a 3.5L DOHC 95SR - Inhibitor switch? [Re: fasteddy] #940645 04/24/09 04:52 AM
I did take it off and clean it up, but it could still be bad, I suppose. It didn't go through a period of being intermittent (except once), but I can still test it. Does anyone know is there is a test procedure in the FSM or somewhere else?
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6435 MB (Peak: 0.7671 MB) Data Comp: Off Server Time: 2026-06-07 09:07:01 UTC
